Results 1 to 16 of 16
Thread: check engine light on
    Senior Member drupason's Avatar
    Woodstock, GA
    Default check engine light on
    alright im throwing some codes, anybody know what is causing and how to fix em?
    P0300-random/multiple cylinder misfire detected
    P0301- Cyl 1 misfire
    P0302- Cyl 3 misfire
    P0303- Cyl 4 misfire
    P0172- System too rich(bank 1) Probaby caused by the misfiring cyl
    IA KING
    have you changed anything in the car's motor?
    IA's deaf kid Deaf Pimp's Avatar
    In my bed...
    Coil packs? Seem to be a common problem with 1.8t motors.
    2005.5 Audi A4 2.0t Quattro
    APR 93/100 Chip
    Quote Originally Posted by Deaf Pimp
    I was thinking the same thing. I've read it on Vortex
    Woodstock, GA
    ive just done intake and dv
    what kinda intake is it? Newer cars dnt take mods well at all. coil packs would cause a rich conditions and misfire but i would think the intake woudl be freaking the mass air flow sensor out causing it to put more fuel than programmed casuing ecu to freak out.
    Woodstock, GA
    if i just reset the codes and clear the check engine light id be able to pass emissions right? i neeeed to get my tags! haha
    Quote Originally Posted by drupason
    NO!! When u clear ur codes/reset ur check engine light/disconnect ur battery it resets all ur monitors. Ur ecu will have to go through all these different emissions system checks b4 u can get tested or theyll tell ur monitors arent ready to be tested. When u get ur codes cleared ur gonna have to drive the car for a while so it can go through various drive cycle which is when it (ur ecu) performs all these tests.
    DC5-R
    Gwinett
    yeh, if its obd2 then once you reset the check light, you will have to drive for 100 miles before the ecu is in ready mode, if you reset it and try to take emissions right away you will not be able to because once they plug it up it will not start because the ecu is not ready.
    Woodstock, GA
    too late! haha i did it thursday...ive gone over 100 miles and no light yet you think i should give it a shot
    IA KING
    intake = air mass
    Woodstock, GA
    ok about 170 miles and still no check engine light you think im clear to try emissions again? i neeed to get my tags
    go for it.
    Woodstock, GA
    go for it.
    alright! if i fail again you owe me 20 dollas! haha just playin
    i charge $100 for internet tech support so just pay pal me $80 if u fail.
    Woodstock, GA
    dammmmmit! alright haha im gonna do it in the mornin so we shall see
