Results 1 to 8 of 8
Thread: Starter issue ???
    Projects
    Default Starter issue ???
    2002 Mitsubishi Galant started to have issues last week thought the engine was locked up. I tried to start it and all I got was a clicking sound.
    I then tried turning the crank with a socket to see if it was locked and it spun fine. Then I tried cranking the car and it started up fine.
    Wellllll Today I go out and try starting the car and all it does is click once again and yes the battery is fine.
    So since I don't have to tools or time at the moment to fix i will have to have a shop repair it. I just wanna make sure it sounds like it is the Starter gone bad before I go wasting money....Opinions ????
    Scottish Scotsman's Avatar
    on the road to recovery
    how do you know the battery is fine? did you take it up to get tested? just because the lights come on , doesnt mean it have enough cold cranking amps , take the starter and battery up to Advance and have them check both before you cart it up to the shop
    Earth
    yup yup
    Projects
    Starter is still on the car cause i cant get to it to take it off. I just took the battery today and got it tested it was good but i got a new battery while I was there anyways and still same issue.
    wait you bought a new battery , when the old tested good ? SMH , have you checked all grounds and the wires going to the starter?
    Projects
    Yeah We needed another battery for another car anyways. I have looked at them and they all appear fine fro what see.
    you need to get it off and have it tested
    Certified Gearhead kevint2's Avatar
    Mar 2012
    Sounds like a bad starter solenoid.On your car is it build in to the starter...replace the Starter and you will be good to go...
