Results 1 to 18 of 18
Thread: what to do?
    Senior Member drupason's Avatar
    Woodstock, GA
    Default what to do?
    alright just recently bought a jetta 1.8t... what mods and in what order should i conisider?
    check out "so i rode in this GTI tonite"....those mods will be fine
    NYC/ATL
    Quote Originally Posted by GTi30R
    True, but he may be looking for something a little less extreme.
    The basics for the 1.8T are as follows:
    Chip (most important, go with GIAC or APR...Paul will chime in soon about EPG, they are the GIAC dealer in GA): Chips are good for ~50hp for $500ish...it is without a doubt the BEST hp/$ ratio you will find.
    After the chip everything else seems less attractive since they have higher prices and less gains however look into the following:
    Exhaust: high flow cat, downpipe, and back, REPLACE EVERYTHING.
    FMIC: Especially in ATL your stock SMIC will get heat soaked REAL quick.
    Intake: Frees up some ponies
    Thoose are the basics i would say, im sure there are some im missing, but thoose are the biggest HP adders on the stock turbo as far as i know. Im sure others will chime in.
    HTH
    -Jordan
    IA KING
    GIAC = 500
    FMIC = 700
    DV = 100
    exhaust = 200
    tt dp w/ hiflo cat = 350
    inlet pipe = 200
    intake = 150
    n75 = 100
    2500$ will cover all of that and you'll be making 200-225whp / 250-275lbs ; 13sec car
    call brian at EPG see what they can do for you.
    Apr 2003
    Acworth/Kennsaw
    Chip and turboback w/satisfy your needs for a little bit
    yup, thats a good list for starters.try looking also in a limited slip diff and clutch package. be cautious when buying these mods because it will save you a lot of money if you decide to go with a larger turbo in the future.
    NYC/ATL
    Assuming its a manual...
    SpeedMonkey_ benwaballs's Avatar
    MI
    Quote Originally Posted by drupason
    BT
    Woodstock, GA
    cool cool thanks guys they chip will be coming soon hopefully
    Loganville Ga
    Chip , DP, and a DV. Exhaust didnt do much for mine...the DP and chip def did! If I had ran slicks w/ chip only I'd hit 13s...almost did w/o. Do APR or GIAC whichever is cheaper.
    I have a shaved (notchless) hood for a jetta 4, Plat gray ..$150 ...And some very clean 03 jetta OEM tail lights for $40
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    Apr 2003
    Acworth/Kennsaw
    Quote Originally Posted by Allstar1.8T
    You got the grill to go w/that hood???
    Chambodia-
    chip and exhaust of course but def get a turbo inlet hose
    and until u get a FMIC, def get the lower intercooler pipe( ABD ) that replaces the pancake pipe.
    oh greg, im interested in your hood..im want to get a custom boser made while my car is getting the kit repaired ..etc
    Loganville Ga
    nope, when I sold the car it took the carbon fiber notchless w/ Kamei grill....
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    somewhere near ur mom...
    put that motor in a mk2!
    the best mod you can do!
    Woodstock, GA
    got the intake and diverter valve on tonight! sounds goooood!
    MI
    should have saved your money and done a chip! intake & dv just make your car sound fast! but its a start
    Woodstock, GA
    yea i know i know chip is coming next!!
    a-town
    u should get 3' Ghl Turbo back they sound great
