Thread: itr 5 lug conversion
    RISKY RISKYB's Avatar
    athens
    Default itr 5 lug conversion
    what all parts do i need to do it?
    the old man NAIZBST's Avatar
    you would need the front knuckles, rotors, pads, and calipers and brackets
    rear you would need the trailing arms and knuckles and you don't need to have the lower control arms because you could use regular integra LCA's , rotors, calipers, caliper bracket, and pads
    what are you going to put this on?
    athens
    my 2000 gsr, thanks for the help, and what about shocks and springs and axles
    IA's Transformer God obd1kenobi's Avatar
    29th Chamber
    PasswordJdm Sells the whole conversion for $1325 shipped, it includes
    Here is a JDM DC '98 Spec Integra Type R 5 Lug Front and Rear Disc Brake Conversion! Larger rotors and calipers for improved braking! Comes in a 5 x 114 bolt pattern. Includes all brake components, front knuckles, and rear trailer arms. This set requires the use of 36mm axles from a JDM '98 spec ITR or you can modify your existing axles to 36mm splines. (USDM B-series axles are 32mm). There are no brake lines, e-brake cable, shocks, springs or lower control arms included in this set.
    That should answer your axle question too.
    GeckoSquad / Skull Platoon
    athens
    thank you
    29th Chamber
    Any time dude
    athens
    where can i get the modified axles to fit my trans 32mm and the other side 36mm
    29th Chamber
    Try Hansport
    athens
    cool
