Results 1 to 4 of 4
Thread: PLease Help!!!!!(Engine Swap)
    Honda/Acura Lover 93Lude's Avatar
    Tennessee
    Arrow PLease Help!!!!!(Engine Swap)
    Will I nedd to reset the Computer or anything in a 1993 Honda Prelude Si????
    What is the procedure I will have to go through to change out the engine???
    It is the exact same engine coming out that I am putting in......
    I just want some instruction on how to do it!!
    I blew the engine and I just biught a new one to go in that is the same kind(H23A1).
    Does any one know any good websites or know them selves how to do it or what to do and what will I need besides a cherrypicker???????
    PLease RESPOND A.S.A.P.
    [email protected] :confused: :confused: :confused:
    Life sucks and then you die, so rev it up and let it fly!
    FOR SALE 93 Prelude Si
    Certified Gearhead MrEG62U's Avatar
    D'ville
    take it to a shop
    posted by 01dc2 jdm
    its just a vtack engine.
    Oviedo, FL
    If you haven't done a engine swap before I wouldn't recommend you start now, unless you don't mind spending money on trial and error fixes :-)
    Overall a engine swap is simple if you know what you are doing
    I plead the 5th burnout1990's Avatar
    FT. Benning
    a haynes manual will be your friend, put back any bolt you take off if possible example if you disconnect a ground wire and you can screw the bolt you took off back into the hole w/o ground wire and anything else you keep loosing bolts and forgeting where shit goes from happining, if its the same motor wouldnt be hard at all as long as you remember what you took off....again haynes manual is your friend if you have never done that before....i got a cherry picker and all the tools needed for a low price pm me if interested
