Results 1 to 40 of 40
Thread: Clutch Questions
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Default Clutch Questions
    Ok So Ive Had My Car For Around 4Months,
    Since i bought it.. the clutch seems a little hard, not soft like i usually see on most cars
    and lets out almost all the way to the top,,
    The guy i bought it from,his story was he replaced the clutch and pressure plate and thats why its hard and lets out high.. he has no paper work... and im no clutch expert so .... is hard clutch is normal????
    && ive had my clutch adjusted but when it got adjusted to release at the middle, the gears didnt go in. so they had to set it how it was, set high! please help!
    barrow county
    its not really a clutch problem, its a clutch peddle problem with sitting too high. never adjusted one before so you will have to wait for another person to answer
    With Your Mom
    but what could cause the clutch pedal to be not soft to any other clutch
    ive head when the clutch is too soft is ready to go out.. but most clutches seem soft soo idk?
    Southside Ridin HATCH
    Sounds like he put a after market clutch...
    But GL if you have a problem.
    With Your Mom
    so the clutch not being so soft is normal?
    It depends on what clutch you have..really...
    If you have a STOCK clutch and it is really stiff.. then hmmm...I cant really think of a reason it feeling harder then usual
    With Your Mom
    yeah previous owner said its a stage 2 or 3 clutch..is there a place i can take it to get it checked out to make sure.
    the sky
    is it cable or hydro?
    With Your Mom
    Quote Originally Posted by jdm-civic View Post
    cable
    Senior Member EJdm's Avatar
    if its cable you can adjust it...follow the cable down to the trans and you'll come across a knob, thats where you adjust it...if its an aftermarket clutch like you said then it should be some what hard...i drove my stock da9 and then drove my friends celica alltrac with ACT 6 puck clutch..that was pretty hard
    With Your Mom
    Quote Originally Posted by EJdm View Post
    yeah i adjusted myself but i rather not mess with it
    and yeah i guess its after market
    && what are the symptoms of a clutch thats going out?
    Take your starter off, what color is the pressure plate??
    With Your Mom
    ill get back at you tomorrow with that one !!
    what color it should be?
    barrow county
    stop adjusting shit before u brake something. there is nothing wrong with the car. the clutch kit that is install doesnt have a oem pressure plate giving u a harder feeling. there is nothing u can do to change that unless u change the pressure plate.
    x2
    X2
    sandy springs
    that doesnt explain why it releases so high. Either the clutch is about used up or the pedal needs to be adjusted.
    Quote Originally Posted by Marta Mike View Post
    he desnt know what kit he has. ive had lots of kits and installed and test drove many more. they all release in different places. some high some low some in the middle.
    sandy springs
    agreed. All im saying is if its too high, something isnt right. For proper diag test drive is needed.
    ^ this....
    If your clutch is goin OUT.. it will be down to the damn floor.. and wont grap at all!
    sandy springs
    ^ this....
    ok..........
    ^ this....
    yah it will on the floor past the carpet before u could get it to engage. that is if it does at all.
    barrow county
    if the clutch is slipping, it'll revv up when your trying to pick up speed. best way is to stump the gas when your moving, if the rpm jumps up and drop back down to catch than its slipping
    youtube may have your answer, im at school so cant post a link
    barrow county
    peddle being high is set by the cable or if hydro, thats the way its going to sit or relocate the peddle
    stiffness of the peddle is the pressure plate ( most of the time )
    sandy springs
    cable is not self adjusting...and if you read, he already stated he does NOT have a hydro trans. And many of the hydro trannies still let you adjust the pedal. So as I said before, its about gone or needs adjusting.
    GTFO!
    sandy springs
    GTFO!
    you want me to gtfo, yet you couldnt answer why a stock clutch would be hard? Lol ok. Ok im out bwahahaha
    OK genious why would a stock clutch be hard????????????????????????
    ITS NOT A STOCK CLUTCH!!
    sandy springs
    genious? Nah I wouldnt say that. And I never said that he had a stock clutch. I believe you were the one that said you have no idea why a stock clutch would be hard......am i correct? Well when a clutch is severely worn or abused, the clutch dust/fibers etc can build up causing a "hard clutch" feel.
    WEll bud most of the time when a clutch is WORN or abused.. It just ISNT there.. GONE.. NADA! there for NO feel at all.. but i guess diff people have diff experience..
    your moms house
    i say get a new car lol jk flex
    ima fuck with your this weekend see what we can do
    (((((No more 4 door))))))
    With Your Mom
    With Your Mom
    reps
    IA Member ReXy5709's Avatar
    Jul 2009
    the zc in my crx had an act 6 puck stage 3 clutch. it was much harder to push than an oem clutch. you can take your starter off to see what color the pressure plate is and that will give an idea if its aftermarket. yellow is act. get someone to push your clutch in while you look at the tranny to find the cable, there will be a round knob around the cable, while the pedal is down twist the knob 3/4 the way or so towards the ground. get in the vechicle, start it up and see how it feels, if it lets out too close to the floor then adjust the knob up. repeat until it lets out where you want it to. if you need further explination you can hit me up, id be glad to help. 706 618 7686 and guys, quit bickering, lets help this guy out.
    Quote Originally Posted by ReXy5709 View Post
    very nooish post. this is IA home to a lot of things 1 of which is "bickering". an he got the answers he was looking for a few times.
    With Your Mom
    thanks! reps!
    yeah i kinda get the idea its "Aftermarket" just not 100% sure
