Results 1 to 8 of 8
Thread: b18c1 leaking oil
    Default b18c1 leaking oil
    Hello all,
    I recently just swapped a b18c1 motor and tranny into my 95 ex coupe. As you can see there is oil dripping out. Now correct me if i'm wrong but before assuming that it's warped I should change out the....
    -Vtec Solenoid Gasket
    And what else?
    Also it's easy to see that the motors been taken apart before. The upper half looks sand blasted and much cleaner than the lower tranny area. Tranny is a 96 and motor is a 94. Also, as seen in the third pic the gasket is not OEM. Typically it would have some engravings visible on it would it not?
    UPDATE:
    Many thanks to barefoot motorsports for helping me narrow it down a bunch. I am ordering a new distributor, the one that was sold to me rattles i'm sure it's on its way out, with a new o-ring and vtec solenoid gaskets (upper and lower). HOPEFULLY this will remedy the issue.
    vtec gasket or dizzy o ring. my money is on the o ring. also u know u have a stolen tranny right. there is only 1 reason for a removed vin plate.
    LAWRENCEVILLE
    MIGHT BE A OVERHEATING ISSUE! ITS SOOOOO HOT THE VIN PLATE "FELL" OFF!
    Hella stock member!
    Quote Originally Posted by silversol View Post
    You guys have got to be shitting me?
    Should I report this guy? He was on CL.
    Riversider
    Quote Originally Posted by Sixth_Vang View Post
    Always blame that "guy"...
    Barefoot PM Sent
    Barefoot PM Sent
    replied
