Results 1 to 24 of 24
Thread: Need Help :Valve Adjustment
    Chickens Eat Eggs
    south side hoe
    Default Need Help :Valve Adjustment
    OK, i have a b18a1(90-91) bottom and a b18b1 (92)head, i need to find out what gauge too use to set my intake and exhaust ASAP!I'm Doing a Valve Adjustment for my DA Integra.....Thanks FOR the HELP!REPPS
    @ballengine ballistic08's Avatar
    Grayson, Georgia
    a feeler gauge
    facebook.com/ballengine
    Chickens Eat Eggs
    south side hoe
    Quote Originally Posted by ballistic08 View Post
    a feeler gauge
    yess, i meant what spec should i use
    Chickens Eat Eggs
    south side hoe
    right now its on 8 and 6 , and its ticking louder...
    Grayson, Georgia
    that seems tight I would've said 8 and 10, It probably says in the car manual. but that may not be the source of your ticking
    Chickens Eat Eggs
    south side hoe
    http://www.g2ic.com/tegtips/engine/21.html
    I know 90-91 heads vs 92-93 heads, the cams are different....,but are the b18a1 and b18b1 bottom are they different as well?
    Chickens Eat Eggs
    south side hoe
    i dont know, 8 and 10 seems like that would be too loose
    *NY Driver* CeOTiO8's Avatar
    In your girl
    Damn I thought Mike did it for you already.... What happened?
    PROUD SUPPORTER OF BAM-TECH WTF?
    Chickens Eat Eggs
    south side hoe
    Quote Originally Posted by CeOTiO8 View Post
    he did, then i accidentally used my remote start in 1rst gear, didnt know the guy put it in first gear when he parked it, after that my valves start ticking again and leaking power-steering fluid somewhere...
    In your girl
    Quote Originally Posted by laokid View Post
    DAMN RICER JK
    WEST_SIDE
    it has been a good mintue but i tought it was 4 intake ; 7 exhaust. plus or minus 1... just remember engine has to be cold.
    WEST_SIDE
    i know crank, deck height, rod lenght are the same other the that i dont see what the diff is. i assume just cylinder heads
    Chickens Eat Eggs
    south side hoe
    Quote Originally Posted by SLow_POke View Post
    hrmmm than i should use the 92-93 specs??????????????
    The 90-91 should be .006-.007 inches intake and .007-.008 inches exhaust
    The 92-93 should be .003-.005 inches intake and .006-.008 inches exhaust.
    WEST_SIDE
    yes i would go with 92 up b18b specs
    Chickens Eat Eggs
    south side hoe
    yeah imma go with the 92-93 specs, but ill probably use 3 for the intake a 6 for the exhaust...........anybodyyy else with different suggestions?
    WEST_SIDE
    i think that will be good, i was saying 4 so it gives u a lil room to play if they where loose.
    either will work fine. i normally go by what the head is as long as its still stock.
    Chickens Eat Eggs
    south side hoe
    used 3 and 6! No ticks, but i recommend setting it in the middle somewhere 4 and 7, i can feel a little drag............
    WEST_SIDE
    good deal. It's always best to leave in the middle.
    intake .006 exhaust .007 is what i usually do
    /Oo ___A___ oO\
    |=_/_______\_=|
    Chickens Eat Eggs
    south side hoe
    yep o well
    Quote Originally Posted by VickNotic View Post
    thats too loose i had .006 and .008, it was ticking
    Newbie Photodude RBS's Avatar
    All Over U S A
    3 is too tight, 6 is on the tight side. i do 7 intake exhaust for those "race" engines
    4 and 7 is fine ........ 3 and 6 is ok.
    I run mine alittle tighter than normal because i like the valves to open alittle faster for more power but what do I know I never built a engine in my life
    Chickens Eat Eggs
    south side hoe
    noo thats too loose, for some reason.... i have a b18b1 head, differents specs than the b18a1 head<---bigger cams i believe
    yeah its okayyy
