Results 1 to 15 of 15
Thread: power doors and passenger side window problem
    Adrenaline Junkie loverboy_gnd's Avatar
    Jan 2010
    Southside
    Default power doors and passenger side window problem
    on my 98 accord, my power locks stopped working, also, the passenger side windows arent working from the driver side control unit, i already checked and replaced all the applicable fuses but still doesnt work, does anyone have any idea on how to fix this problem? reps for any help i can get, thx
    CANT STOP WHAT YOU CANT CATCH
    :idb::boobies:I EAT PUSSY FOR REPS! LOL :boobies::idb:
    Новак 5speed's Avatar
    Conyers, GA
    motors maybe? Find used ones and replace them.
    Amen.
    Jan 2010
    Southside
    Quote Originally Posted by 5speed View Post
    thats the thing, the windows work fine when operated from the passenger side, but when you try to turn them down / up from the driver side main panel, its not working, and the power locks not working period, im completely lost as to wht else could be the problem
    Conyers, GA
    Could be wiring I guess. I don't know. I have always had manual everything lol
    Amen.
    Jan 2010
    Southside
    lol, i changed the fuses, took down the door panel and checked the wiring to it, i dunno man... shit sux, ++ for trying though
    Conyers, GA
    Thanks. I have worked on them before with friends who had similar problems. Fuses and motors have always been the problem.
    Amen.
    Jan 2010
    Southside
    FIXED!!!!!!!!!1, i had to turn the windshield wiper ring to the middle position, then start the car for 10 secs then cut it off again, did tht and now everything works fine again!!!!!!!! thanks 5speed for tryna help
    lost 3'' in 3 hrs!!! 1moreaccord's Avatar
    l'ville
    Quote Originally Posted by loverboy_gnd View Post
    aight hold up a sec - I jus got on here to research how to fix my 95 been havin the SAME EXACT problems too weird man, so how exactly you fix it?
    Conyers, GA
    That is weird as fuck. I don't understand.
    Amen.
    Jan 2010
    Southside
    apparently it resets itself after tht... who knew
    l'ville
    it dint lol.. TBH I think it's just luck that it happened to fix yours this time and it might jus happen again, but hopefully it did it for good!
    Mine started bout 7-8 months ago goin out every once in a while, then progressively got worse until now they never work.
    Anybody got any other suggestions?
    Jan 2010
    Southside
    ok you know the int timer ring, its right in front the window wiper switch, you use that to determine how fast the int mode ont the wiper goes, you turn that to the middle position, then you turn the car on for 10 secs, then turn it back off and bam everything works fine again, hope it works out for you too
    Jan 2010
    Southside
    wait what did you turn to the middle position, was it the actual wiper? or was it the ring, when you turned on the car for 10 secs did the window wipers come on?
    l'ville
    hmm.. yes it was the wipers, they came on when I turned the car on. Also - my car is the model b4 yours, so the wiper adjustment is a little different
    Jan 2010
    Southside
    ok well in my car, its not the wipers, on the same knob for the wipers, right infront of it there should be another one with that spins freely, its called the int timer you have to turn that to the middle position when yu start the car, your wipers should not come on, maybe theres a difference in the models, but check to see if you have that knob
