Results 1 to 26 of 26
Thread: spindle question
    tawksick. toxxxic's Avatar
    Roswell
    Default spindle question
    so as many of you know, i tried to fly my del sol this weekend.
    anywho - i need a new spindle because the wheel bearing and ball joints are bad, so i'm just going to replace the whole thing. when i replaced my brakes a couple months back, my bf noticed that my brake setup was not the same as his on his 94 civic ex. is there another car that has the same setup as a 93 del sol si that i could get a spindle off of?
    West palm beach
    any 92-95 civic spindle should work....
    NO ADVERTISING
    -IA MANAGEMENT
    Roswell
    nope. not the same. i need like the hub and all.
    West palm beach
    NO ADVERTISING
    -IA MANAGEMENT
    Roswell
    no no no, the ENTIRE thing. i guess the "knuckle" would be a better word?
    Around metro-ATLANTA & IA!!
    i got a spindle with a new ball joint on it. with good wheel bearing. it came off of a 92-95 DX. mines a driverside. you didnt say which one u needed? or both?
    Roswell
    I have an Si, I don't think it will work. I don't want to swap out brakes. Like I said, my calipers/rotors wont work on the EJ1. They're completely different.
    But I do need the drivers' side.
    Newbie Photodude RBS's Avatar
    All Over U S A
    your kinda stuck in this boat i would say, you can only use a delsol si spindle. if anything swap both spindles
    Certified Gearhead Umby's Avatar
    L'ville / Gwinnett
    Del Sol Si or Civic Si... They're the only cars that used that particular set-up from what I can tell
    Roswell
    aw poo
    L'ville / Gwinnett
    You could swap out the entire assembly for both sides with parts from another model... but I would try to find the right one first
    GL
    Oct 2008
    wheel bearing plus ball joint will probably be like 50-60 bucks worth of parts.....probably best option unless you bent it out of shape
    Did you try car-parts.com? This is a nationwide search from junkyards. You can do a regional search also. Use it all the time to gauge parts availability...
    del sol? 94_teg_ls's Avatar
    i am about to swap my brakes with donor teg if you still need some when i do you can pick them up
    South Side Georgia
    I paid $20 for both lower ball joint at O'reillys (Hook up). They were easy to remove and install..
    resize pic
    Quote Originally Posted by gerardojdm View Post
    What made it easy? i hate ball joints.....
    South Side Georgia
    Quote Originally Posted by LongLiveH2b View Post
    It really wasn't hard at all despite it being my first time doing it. I hammer it out in seconds and put WD-40 to lubricate it and hammered it back.. Putting it back took a little longer..
    It's not hard unless you are a complete fool and don't know what you're doing. No special tools needed too...
    resize pic
    South Side Georgia
    Oh, and don't forget the clip thingy that keeps the ball joint in place..
    resize pic
    if you need the whole spindle off a DEL SOL SI or a CIVIC SI good luck as those are the hardest cars to find in junk yards. They are extremely rare in junkyards, and on top of that, most junkyards classify all civics and del sols the same.
    IMO Call Honda Parts Connection and see if they have it, if not, you are better off buying "regular" brakes off a Civic or Integra and swapping BOTH sides.
    Senior Member ej6kidd's Avatar
    dallas
    i have a del sol si and i just change one of my knuckles with one off a92-95 civic worked perfect no problems
    She might have integra brakes or something
    somewhere, GA
    Just go find the front spindles from an ls or gsr and swap both sides....so easy a caveman could do it.
    Tell your BF to get his game up.
    '82 TE72 SR5 Sport Coupe
    3tc
    Roswell
    Quote Originally Posted by D3UC3S View Post
    I dont want to do that. I wanna keep everything factory. I don't like mismatched shit.
    Augusta
    Did the EX have abs? It has the teg front spindle. Any 92-95 Civic with 9 inch rotors will work.
    somewhere, GA
    bigger calipers and brakes would actually be safer...its still from the honda factory
    3tc
    cleveland,tenn
    lol mind if i ask how did u fly your del sol over the weekend?
