Results 1 to 18 of 18
Thread: wire tuck help
    Default wire tuck help
    Iv been wanting to do a mild wire tuck on my teg but dont knw how to start or if its even worth it. any tips, advice, or input is welcome and appreciated.
    Jul 2009
    you only need electrical tape and some tinners snips and maybe some of that wire that comes in rolls from auto zone..... you know the black stuff...
    just start cutting your wires and extend them a little bit.... then twist the wires real tight so they dont come loose and tape em up....
    Aug 2009
    Lawrenceville, Georgia, United States
    Make sure you do it right you don't want any problems. Solder the wires together don't twist them real tight and tape it lol. Put heat shrink after you solder every wire together.
    Quote Originally Posted by AyO Deebo View Post
    x2
    had a good laugh for twisting real tight! two words electrical fire!
    Hit u w/ ur own pimp
    Oct 2009
    My tool box
    If you're looking to do I MILD tuck I believe you don't need any tape, wire, or solder. Simply route both body harness' from the shock tower under the frame rail towards the head lamps. Im pretty sure you only need adell clamps and screws and you're set. You could also route both harness' through the opposite hole where the brake line runs through. Up to you.
    aye bro .:Stirfry:.'s Avatar
    Quote Originally Posted by Kserieskid View Post
    x2 if you just doin the lights they will reach with no prob.
    ATL DAsquad Member #9
    Newbie Photodude RBS's Avatar
    All Over U S A
    buy a notebook and record everything you do as you do it, so when you come in here asking for help we can go straight to the problem
    i dnt wna end up with problems?
    Columbus
    Quote Originally Posted by CautionMeDC2 View Post
    if you ask how to do a wire tuck, and you start cutting and twisting wires together...you will hit some snags. lol.
    Quote Originally Posted by 99jdmLs View Post
    havnt started yet.? and dnt plan on cutting ne wires unless i have to extend some but i doubt it
    GoooooooooooN shane94's Avatar
    Gainesville/Oakwood/Flower Branch
    then ask Got_Purp how to do it, he did mine
    Southside Ridin HATCH
    ^ haha
    if you are just trying to tuck the passenger and driver side harness for the lights and what not.
    just unplug everything and trace it back to where it enters the firewall.
    pull it all through and run the wires through the door harness hole
    secure the wires to the frame rail and plug everything back up
    vanilla sky.
    i wish i never did my tuck.
    Quote Originally Posted by silverDA View Post
    wwuuut?
    South Side Georgia
    if you are you are planning on doing an wire tuck and asking for help then thats a big recipt for failure.... seriously!!!!!!!! leave it alone an find something else to do
    resize pic
    Just leave it alone, leave it how Honda intended!
