Results 1 to 15 of 15
Thread: vtec solinoid gasket help
    revolution big mac's Avatar
    Default vtec solinoid gasket help
    aight so i am ina bit of a pickle here and am in need of help from the ia gurus. i have a ls vtec setuop and its was leaking oil. changed the dizzy oring and it help but the vtec solinoid. im pretty sure that the head that i have is a b16a. if i remember the code on it is pr3. what car should i order the gaskets for it from for the vtec solinoid? ive head two main ones which are nsx and 94 del sol with the b16 a3 i believe. any useful help will be repped. thanks ia
    West palm beach
    any b-series vtec solenoid gasket should work
    NO ADVERTISING
    -IA MANAGEMENT
    not according to the people of honda tech. lol. aparently its different. so im just trying to get things straightened out
    West palm beach
    Quote Originally Posted by big mac View Post
    thats news to me, I've used the same one on b16's and gsr heads....But the B17 and OBD0 may be different, I doubt it though. Just cross the part #'s if your not sure, honda and acura should have them in stock. You could just take the old one with you.....
    NO ADVERTISING
    -IA MANAGEMENT
    Hiram/Dallas area
    b16a3 came in the 99 si civics, on worldpac parts catalogue, they call it a "spool valve strainer w/ gasket" (or something similar) because it has a metal strainer in the oil feed. there is another spool valve gasket that goes between two parts of the solenoid, not the solenoid to head. i have replaced a few of these lately on an obd1 b18c and a 99 b16a3. i have to agree with punkr6, they looked exactly the same to me.
    the cam plugs that i replaced at the same time though, looked different, but im sure they'd interchange.
    the big one goes between the cylinder head and the solenoid itself.
    Attached Thumbnails Attached Thumbnails -honda_vtec_solenoid_gasket_pm-jpg   -41abpet9ddl__sl500_aa280_-jpg
    Im pretty sure that they are all the same but just get the year off the head and we can kinda figure out what the head is off of... On the front of the head right above the exhaust manifold there will be a few little circle looking things with numbers in them. like 93 (1993), 98 (1998) .....That will help...
    Atlanta, Ga
    jdm b16a is the nsx one, and the usdm one is just whatever the dealership gives you. i've had to change one of each lol. you can realistically make either work for either application i think. one is just a liiiitttle bit larger than the other and one has rounded vs kinda squared edges. i know after doing some research on honda-tech i found the actual honda part # for each application though, do some more research if you're not 100% confident.
    lawrenceville,ga
    even the gasket from a zc single cam will fit on it.. i got a b16 head pr3 and i got the gasket from a 2000 si and it fit. gsr and b16 are the same
    okay so i looked at the cirles on the head the first one is 95 second says 5 and third is 80 followed by pr3-3. judging by the 95 i guess it is a 1995 which would make it obd1. vorrect? if it is then i should be able to use an easier to find one like the b16a2 one from the 99-00 em1's.
    anymore input from anybody else?
    vanilla sky.
    is it non obd b16,if it is it will take either nsx 90-91 gasket or gsr b17 gasket/
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    Dont listen to honda tech, there homo's... As said before, any b-series gasket will work...
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    i would asume that also but there are quite a bit of threads in ht where folks but them and bont fit. in most cases it is bc of it being obd0. since the head i a 1995 judging by the stamps on it that would make it obd1 which in my guess would mean that i could use any b series. i just want someone to back up my theory before i go and buy it. does anybody know a good website where i could order it off of?
    yea that would make it a 95... I would get one for a 95 GSR ... Bet it will work... take yours off and take it with you just to be sure... But even though its a 95 B16 (obd1) head I would be almost poitive a 95 GSR one would work.
    im going to order off line bc the local parts stores cant get them for some reqason
