Results 1 to 13 of 13
Thread: Stock cam with high compression
    Out the game again!!
    southside of the border
    Default Stock cam with high compression
    I have a d16z6 and basically the cam i have for my setup is fucked so i cant use it. So my compression is around 12.6:1 according to zealworks comp calulator. So i have to either run stock cam or get another one i cant afford anything atm. Whats the worst that could happenn if i run stock cam with that high compression?
    Soon!!
    ѦʈʃѦŋʈѦ
    Wait til you can afford the right cams...
    2.2 CL
    im running stock cam on 12:5:1 oversized pistons and have had zero problems. d16a6 head jdm d15b block
    lol only on cam, and yea i was thinking that i know if i was to run it like that ill lose alot of power and risk detonating
    Soon!!
    Quote Originally Posted by SLo_MKIII View Post
    are you tuned or just basemap what type of gas are you using
    Soon!!
    2.2 CL
    Quote Originally Posted by allmotorX View Post
    no tune or basemap factory crx si ecu. 93.
    however i tried 89 once and it car literally wouldnt move.
    Oh damn thanks for the input
    Soon!!
    everywhere & nowhere
    No offense - but I wouldn't listen to a guy who runs 12.5 CR untuned. And then a guy who would put 89 octane on a 12.5 CR setup.
    You can "cheat" a bit by running a cam gear and doing some angle changes 1 or 2 degrees in either direction. But if you have a car to use as a DD wait until you can get a cam w/ with more lift and duration. You are actually above the limits of pump gas at 12.6 (untuned).
    2.2 CL
    np, but as stated before if you can wait and save up the money for a cam you might bring a little bit of "beast" out of the D
    Thats the plan
    Soon!!
    you can run the stock or aftermarket cam, but the tune will be different for both. @ 12.5 comp you will detonate if it's untuned on either cam. you will obviously benfit more from the aftermarket cam, but you can do either. i would recommend waiting on the aftermarket cam then tuning it, unless you want to get it tuned twice.
    Southside Ridin HATCH
    How much is the cam les?
    ^^350 for one freaking cam, it was cool when i had a job
    Soon!!
