Results 1 to 23 of 23
Thread: Oil pan gasket issues
    Power to Weight = Me
    CLEVELAND, TN
    Default Oil pan gasket issues
    ok i have ek with ls/vtec. my oil pan was leaking so i pulled it and tried rtv which is what one of my buddies recommended. should i use gasket or just rtv and i dont have a torque wrench so how tight? and if i can get torque wrench what is ft/lbs?
    H22a Si hatch
    Reppin Cage DAILY
    turbos
    8.7 ft/lbs which is 104.4in/lbs. (thank you honda-tech) you will need an in/lbs torque wrench
    p.s. use honda bond
    TOO BIG
    replace the gasket stop doing shit half ass
    make sure you get the metal washers off the block and old silicone off... I wouldnt use a torque wrench just snug them on. then once you are done, you can always go back and re tighten if needed. But if you over tighten and break them you are screwed
    those lil metal rings will fuck you up if you forget em.
    Southside
    QFT
    Hwy 315
    Quote Originally Posted by LSVTECEJ View Post
    sounds like you've got some smart buddies.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    hahah def the wrong idea on rtv...
    i would only snug them maybe a quarter of a turn after you feel resistance, too much can cause it to leak, may cause the gasket not to fit snug.
    should jus do it the right way and torque them down.
    CLEVELAND, TN
    what metal washers are you talking about?
    H22a Si hatch
    Reppin Cage DAILY
    CLEVELAND, TN
    [quote=ASE*Tech;38588036]replace the gasket stop doing shit half ass
    H22a Si hatch
    Reppin Cage DAILY
    Whats next? lcortes32's Avatar
    Dec 2008
    Atlanta/SO*CAL/Nashville
    GL with that LS/Vtec its had LOTS Of problems...
    It also has a blown head gasket i belive..
    and piston rings goin out...
    i know the guy that owned it thats why he traded it
    Just a heads up
    93 Civic EX - Current
    95 Acura Integra GSR-Traded
    99 civic ex-Traded
    95 Civic EG DX Hatch -Traded
    96 Civic DX Coupe -Tradded
    98 Civic EX Fo' Do' -R.I.P
    93 Civic Si Hatchback (Miss you so much Buddy)
    93 Acura DA9 (R.I.P)
    97 Civic EK Coupe(tradded)
    97 Accord SE (traded)
    Jul 2009
    use the grey rtv.....on a new pan gasket......
    but..... windshield uerethane is awesome.....seriously that shit is great
    Quote Originally Posted by lcortes32 View Post
    Just a heads up
    nice heads up after the fact.
    gotrice? gotrice?'s Avatar
    gwinnett county
    use oem gaskets.. they seem to almost never leak... and there is another place to get the best sealer... its the mack truck dealership! they make a sealer that is rediculous..... u can put that shit on the gasket covered in shit and it will still seal..its the shit.. if your still having leaking problems doing what ase*tech said then try it.. and dont smear a whole tube of grey silicone on the pan and another tube on the block. u dont need alot.. in the corners and where surfaces meet does it just fine.. use honda gaskets!!! ive put prolly over 50 oil pan gaskets on and i dont have any problems
    CHECK OUT MY **HUGE PARTS SALE**
    I replaced my leaky oil pan gasket with a Fel-Pro after scraping off all the old material and wiping it clean, tightening all the bolts in a criss-cross pattern but NO gasket bond (I was told not to) and well it still leaks but not as bad.
    I blame it on the non-OEM gasket and not because I didn't use any bond.
    gwinnett county
    well u are right the felpro gaskets are garbage for the honda oil pans... not worth the couple bucks u save from buyin oe.... its 20-25 bucks for oe dont cheap out
    Quote Originally Posted by KevinT707 View Post
    I have used these gaskets more then I can count with never one issue or come back.... guess its the person installing it .
    gwinnett county
    well i have used these a couple times and bad luck all the time... maybe u just that good....but if its the blue felpro gasket they are crappy.. thats all im sayin
    oh yes the blue is a POS!!!!!
    I use the black one!!!
    felpro orange,blue,gray ARE POS
    ^hell ya the orange valve cover gaskets are SHITTY, you put on on, if you ever take the VC off they are stretched and cant re-use them
    1994 Honda Civic SI - KPOWA
    HybridRacing/ALLINFAB/KARCEPTS/K-Tuned/Bride/TopOneAERO
    aye bro .:Stirfry:.'s Avatar
    honda bond
    ATL DAsquad Member #9
    Senior Member DustnU's Avatar
    I'm on a boat!!
    (USE Honda bond). Criss cross pattern hand tight then just snug em down with a 18v drill. I was a Honda tech and did these all day. Works every time makw sure it's clean as HELL!!! Good luck.
    Work in progressneed slicks!
    No wonder .. they gave me the blue Fel-Pro
    I'm on a boat!!
    ^^hows ur car comin along after the wreck?
