Results 1 to 30 of 30
Thread: Car wont Start
    Projects
    Default Car wont Start
    So i just bough this civic about 3 months ago and drove it home car ran and drove fine. I parked it up till today not needing to drive it. I tried starting the car and it wont fire up but just turns over. I check for a spark at the wires and Dist. and nothing.
    I have swapped out the cap,rotor,wires and still no spark.
    When i turn the switch over i notice no CEL is on or even working.
    Shouldn't it come on when star6t up ?
    HELP!!!!
    Car is a 96 coupe
    Battery? Later, QD.
    Projects
    Battery? Later, QD.
    battery is good and charged
    It's all about JDM.
    CA to GA
    check alternator, any loose power lines to your fuse box and starter, any fuses blown, check you timing belt (to see if i didnt snap, or missing teeths)
    Projects
    Quote Originally Posted by gsrteg View Post
    all these things are fine and i read that if my CEL isnt coming on then no power to the ECU so i may have a issue there
    aye bro .:Stirfry:.'s Avatar
    what about the coil in the dizzy. did you check that
    ATL DAsquad Member #9
    Projects
    Quote Originally Posted by .:Stirfry:. View Post
    yes those are good but would those effect my CEL not working ?
    PEENGONE Hektik's Avatar
    check all your grounds...
    Projects
    Quote Originally Posted by Hektik View Post
    locations ?
    :noitacoL
    check your starter. my wifes car did the same thing yesterday and it was the starter.
    Projects
    Quote Originally Posted by uproot View Post
    Starter works good car turns over fine also.....will this cause the CEL not to come on ?
    Are you sure it isn't the battery? I let my other car sit and it drains the battery after while. Three months is long time to sit. Hell i have to trickle charge it to maintain some sort of charge on it and the car is driven a few times a month to keep it flowing. Now the battery is low and i drive it for 30 min to juice it back up but eventually i'm gonna have to replace it. Trickle charge is your friend.....
    Projects
    Quote Originally Posted by civicturbo10 View Post
    new battery just installed
    Quote Originally Posted by hondalover00 View Post
    pm ash7....he'll know what to do
    lol ok
    Well new batteries can go bad if you have a constant parasitic draw. Just sayin....
    Hey does your headlights come on? Just curious....
    Projects
    yeah and i even had a car jumping it so i wouldnt drain my new battery so i know 100% its not a battery power issue
    HHHMMM....
    Check main relay? Common wear item...for my model.
    somewhere, GA
    yes...borrow a friends working main relay and see what happens
    '82 TE72 SR5 Sport Coupe
    3tc
    Norcross
    this happened to be before. and it was the battery. even jumping the battery wouldnt work. so i ended up connecting a bigger batter from another car n it worked. try it.
    somewhere, GA
    This is true also...did you get a battery with enough CCA's?
    3tc
    Projects
    HHHMMM....
    I am tomorrow
    Quote Originally Posted by D3UC3S View Post
    I will see tomorrow a buddy has one i will try
    Quote Originally Posted by j0nbunklah0m View Post
    I did i was using jumpers with a grand marquis and its bigass battery lol
    General Tech Hater
    Honestly man with no CEL coming on at all, as long as it came on when the car was starting fine, could be an ECU issue. check behind the carpet for moisture and then find someone who has a good working ECU and try swapping them around..
    Official "Delete the clubs/crew section of IA" Member #1
    Quote Originally Posted by chouston86 View Post
    So this is how it goes down when I beat you I want the cash and the respect. To some people thats more important. Sounds familiar?
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    test another ecu may be faulty or just recheck all your wiring
    Projects
    Quote Originally Posted by MidLifeCrisis View Post
    yeahs its gay it ran and drove fine and i checked around it looks fine ill try the relay t/m then move to the ECU if no luck.
    Quote Originally Posted by STRteg View Post
    yeah maybe
    West palm beach
    main relay or dizzy, How did you check the dizzy ?
    also can you hear the fuel pump come on when you turn the key on...?
    NO ADVERTISING
    -IA MANAGEMENT
    Projects
    i checked to see if it had power going to the terminals lol
    I dont think i did hear the pump either but i know the main relay isnt clicking when the key is turned like its supposed to do.
    somewhere, GA
    Quote Originally Posted by JDMJAY View Post
    there is your problem
    3tc
    Projects
    Yeah i think so and hope so also...Tomorrow i will know for sure keep fingers crossed
    Projects
    A Ground wire for my ECU that was on the Thermostat house was barely on due to being broke. I fixed it and the car runs fine now. Thanks everyone and reps to all that helped when i can rep again !!
    B-Town Crunk Force
    Statesboro, GA
    Same damn thing happened to me.
    I spent hours underneath the dash tracing grounds and power wires.lol
    center field
    main relay
