Results 1 to 7 of 7
Thread: Carb and engine HELP!!!!!
    Projects
    Default Carb and engine HELP!!!!!
    ok who here knows a good bit about carburetors and v8 motors ?
    Stang Mod slostang's Avatar
    Southside
    whats the problem?
    It's obviously a vac leak.
    Seriously though more information might help us figure this out.
    What do you want to know?
    Projects
    well i got this ford truck and it has a 460 with a edelbrock carb and the truck is idling high and sputtering after i turn the switch off. It is hard to start back but at time then sometimes it idles fine and low just right. Well i took the idle screw out some to see if thats it and hell its still high and running by its self with no screw at all WTF ????
    georgia
    did you check the timing?
    yes i am....
    Projects
    Quote Originally Posted by THEONE View Post
    i checked to see if the dist was loose and it wasnt and it will be normal idle sometimes and perr so nice then it goes high sometimes like the idle or timing change by it self
