Results 1 to 15 of 15
Thread: Headgasket Question.
    Bad Luck kID FAM0U5's Avatar
    Dec 2008
    Default Headgasket Question.
    Ok Ive talked to countless people and I cant really get a striaght answer.
    So the question is I have a NA/T supra Im putting in arp head studs and I was wondering If I need to change the thickness of the headgasket. I thought that the TT motor may have a thicker size but to my results its not, So Im stuck wondering if I should buy another OEM headgastket and spray it with copper gasket overlay thingy. To provide abit more protection.. Im trying to reach 10-12 psi.
    Anyone that can provide me info will be given reps
    Newbie Photodude RBS's Avatar
    All Over U S A
    if your oem gasket and the turbo gasket is the same thickness, then get a new oem one. keep in mind your compression and the TT compression ratio though, if you need to get a thicker gasket to compensate then do that.
    otherwise, get a new oem gasket and dont spray it with copper spray. a new gasket is meant to seal on its own, raw.
    Dec 2008
    I know its different compression ratio however I dont know how to figure that out nor know how to compensate for it.
    @thens!!!!! fools
    Quote Originally Posted by FAM0U5 View Post
    Im telling ya bro if you check out that website their are some na-t genius's over there. And there is no shit talking your questions will be answered promptly.
    Dec 2008
    I cant go on another forum since Im on my ps3 broswer so I cant make new account at other websites.
    @thens!!!!! fools
    Check out Clubna-t.com they specialize in na-t 2jz motors and they will be able to answer every question under the sun for you.
    Dec 2008
    Thanks man.
    Fahrvergnügen Ziptied's Avatar
    Jun 2009
    Charleston, SC
    If you do the OEM and copper spray you should be good for the boost you wanna run, just dont buy a cometic, they are crap.
    Quote Originally Posted by Ms Dollar View Post
    You haven't told anyone that those are my boobs in your avatar right? Wouldn't want people going crazy or anything...I know how you get jealous
    a tt oem headgasket on a NA-T setup will give you 9.2 to 1 comp. This is absolutely what I would do at the boost level you want..
    Dec 2008
    Quote Originally Posted by TommyD1919 View Post
    there is no difference in the size of GE or TT model...
    Jul 2009
    and yes use copper seal.... it works great..
    i never used copper seal on any of mine but hey if it works it works... We've used it on big inch nitrous engines but never on a street engine.. I did watch a guy that was building a Harley engine spray paint the head gaskets before he put them on.. I love the old school crowd..
    Jul 2009
    thats what im talking about..... the copper gasket spray
    not the copper head gasket
    JDM TYTE AnthonyF's Avatar
    Cumming
    head studs allow for more boost pressure and no head lift.
    You wont have to change your head gasket if you swap them over one by one. If you un-do all of your head bolts at once, you pretty much need a new head gasket.
    if you are wanting to lower the compression the "cheaper" way a copper or any type of thicker gasket will work. I recommend Cometic.
    Ziptied bashed them above, but a close friend and member of the VCA club was running 1600 rwhp with a cometic.
    -Ant.
    The Carbon Fibered R6
    TT headgasket is 1.3mm..... There is absolutely a difference.
