Wehn you first build an engine, i know about building the pressure up in the block before you even get to start it... But the question that i have is where should i install the sensor for my oil pressure gauge? I only ask this because on the VTEC heads, there is also a port there that can be used for verifying oil pressure, in addition to the one on the back of the block. So, i was wondering which hole would be better for monitoring things inside the motor?
