Results 1 to 14 of 14
Thread: non stop beeping lol
    F.A.N.A.T.I.C. primespark22's Avatar
    Default non stop beeping lol
    ik i got a 92 da9,when i turn the car on and close the doors it makes a beeping sound its every half second,as if letting me know the seatbelt needs to be put on.the only issue is they are on everything is plugged in right no burnt fuses and it wont go away,is there a way to shut it of by unplugging something?until saturday i drove with it like that now that i have a radio its a lil better since i just crank the volume but it needs to stop,any help will earn green lol
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    rock da sohc
    loganville
    Some where in the door jam there should be a plunger type thing that gets pressed when the door closes take that
    out and unplug it it wil act as the door is always closed that might help. If not unplug the wire from the seatbelt assembly
    thanks ima try that
    vanilla sky.
    are the seatbelts working correctly?
    ^^yup all work perfect
    lol this i huge guessing game your going to have to go in find whats beeping. figure out the system its in diag from there. anything else u do is a waste of time.
    West palm beach
    x2...
    NO ADVERTISING
    -IA MANAGEMENT
    i took the seats out and checked the wiring then plugged everything back and still nothing,i was hoping that there would be a fuse or relay i could unplug and be done with lol,b4 i had the radio i would drive with my windows down and at red lights people would turn around and ask what is wrong with my car lol
    vanilla sky.
    what makes it beep is under the passenger side dash right of the ecu there is a small panel that clips in.take it off and there is 2 small computer things disconnect and replug see if that helps/
    Quote Originally Posted by primespark22 View Post
    u are proving my point faster than i thought.
    West palm beach
    You should be use to this son.....
    NO ADVERTISING
    -IA MANAGEMENT
    Warner robins ,Ga
    its a da you cant expect much from it.
    i am. ive just never had an i told u so moment so soon.
    well it was a premature celebration,i had the seats out already since a gallon of water spilled on the carpet.while i was cleaning it i thought about and said while the seat are out might aswell check,and this was b4 i posted this thread,sorry next time maybe lol
