Results 1 to 24 of 24
Thread: integra running cold all the time
    KINGZOFSOUTHTOWN
    Norcross
    Default integra running cold all the time
    Okay i was just wondering why my integra is running cold all the time. i took it on 85 for about 30 minutes driving around 80 MPH and it's still on the C. whats wierd is when i come to a stop then the temperature goes up to normal? and then right when i start driving it goes back down the the C. And my heat doesn't work well any ideas?
    -hmgdrfter-
    PP TRACK 350Z
    Flowery Branch, GA
    thermostat?
    KINGZOFSOUTHTOWN
    Norcross
    Quote Originally Posted by bdydrpdmazda View Post
    thermostat?
    idk im just checking if anyone knows whats up before i start replacing things i don't need to.. idk if a thermostat would cause the problem though, usually a thermostat only causes car to over heat if you have a bad one, it wouldn't make your car run cold... unless you are saying maybe i don't have one at all thats why im running cold, but still if you don't have one you shouldn't run cold all day.
    -hmgdrfter-
    PP TRACK 350Z
    ehhhh
    Quote Originally Posted by HMGDRFTER View Post
    Now you know what to replace. Just got around to replacing mine now that its chilly sometimes and need a little heat!
    thermo stuck open
    x55
    Sep 2009
    are u running a thermostat in ur car ? and if u are its possibly stuck open.
    B-Town Crunk Force
    Statesboro, GA
    Thermostat is the problem.
    Either youre not running one or yours is stuck open, as was previously stated.
    West palm beach
    Quote Originally Posted by jdm>usdm View Post
    NO ADVERTISING
    -IA MANAGEMENT
    driftoritos ftw!!!
    ^ agreed with above have had this problem before
    “The only thing that could make free gumballs better is if I could get the quarter out of that machine”…03Rcode
    KINGZOFSOUTHTOWN
    Norcross
    Alright thanks guy, will be replacing tomorrow .. reps to all.
    -hmgdrfter-
    PP TRACK 350Z
    KINGZOFSOUTHTOWN
    Norcross
    alright got it fixed, car is running the right tmeperature now but my heat is still kinda semi cold and hot? it gets warm i have to run it past like 6000 rpm though? otherwise the heat is not hot enough, i mean its warm, but its not gonna be hot enough during winter is what im tryin to get to.. unless i run it pass 6000
    -hmgdrfter-
    PP TRACK 350Z
    got enough coolant in there
    KINGZOFSOUTHTOWN
    Norcross
    put 3/4 of the coolant in and mixed the rest with water. its about 50/50
    -hmgdrfter-
    PP TRACK 350Z
    bleed the system?
    KINGZOFSOUTHTOWN
    Norcross
    bleed the system?
    yes everything was done when i took of the hose and bleed the radiator when i installed the new thermostats.
    -hmgdrfter-
    PP TRACK 350Z
    if u got fluid and no air in lines u should have heat. unless u got a issue with the heater core.
    Oct 2009
    G-Net G.A.
    my car do the same thing to but how do i know where all the stuff you guys are saying located at new to the game so need a lil help guys.
    Quote Originally Posted by J_Mee_5 View Post
    year make model swap mods
    ehhhh
    And you bled the system correctly? Did you try moving the lever in the engine bay that controls the flow of coolant to the heater core by hand? Perhaps a problem with your temp knob/ and the metal wire that connects the two?
    Oct 2009
    G-Net G.A.
    its a 95 integra b18 b1.
    KINGZOFSOUTHTOWN
    Norcross
    got it fixed, heater core...
    -hmgdrfter-
    PP TRACK 350Z
    im am on a roll woot
    The ShotkallA Complete's Avatar
    j_mee_5 check your pm
    Complete
