Results 1 to 15 of 15
Thread: 1990 miata thermostat problem
    douglasville
    Default 1990 miata thermostat problem
    I installed a new thermostat the other day and now when the car gets to normal temp it shuts off. could the thermostat possibly be facing the wrong direction, i was careless when i took it out and didnt pay attention to where the little copper pin was facing. anyone have experience with this?
    YR88 Win! Romeo's Avatar
    Middle Ga.
    It shouldn't just shut off. Is it getting real hot or anything?
    rolla rollin
    middle GA
    im sure his original post just said that it was gettin to normal temp! please read before you post thanks
    Middle Ga.
    You going to follow me after every post? LOL.
    as for y its shitting i have no clue in the world. based off the info provided.
    douglasville
    i was also having an IAC issue before this? could the IAC cause it not to run once it gets to normal temp?
    One Curve At A Time
    MX5atlanta might be more help. I dont know why it'd shut off. Even if it was over-heating there would be damage done, not an auto-shutoff. Wierd idle or anything showing a vac leak? have you done a comp test to check damage to the head gasket?
    97 DX Civic w/ H22 FS
    douglasville
    Quote Originally Posted by FlipKing View Post
    comp is 155 all the way across, this shit is just confusing the fuck out of me.
    One Curve At A Time
    You hook up all the sensors correctly?
    douglasville
    rodger. shit is trippin me out, im thinkin maybe the new thermo is just faulty cause the IAC has to have coolant run trough it to work correctly and if the thermo isnt opening up at normal temp (like it should) then the IAC wouldnt be sufficient.
    One Curve At A Time
    Maybe man, idk. It is def wierd
    ALL CAPS JITB's Avatar
    u should check the iacv. I have never seen it get that bad where it cuts off. does it sputter and die slow? or just cut off? you can bypass it and run the car and see if that helps. its been awhile since I worked on a b6. but it sounds like that might be your problem.
    douglasville
    Quote Originally Posted by JITB View Post
    yes, when it gets to normal temp it will start to sputter and then just die and not crank back till its cooled down.
    Quote Originally Posted by dohc4.6sc View Post
    that sounds like a bad sensor. fine when cold fucked when hot.
    if uu got the cash replace both. but I have heard of mazdas doing this due to a bad temp sensor.
