Results 1 to 6 of 6
Thread: ckf splicing
    Jul 2009
    Default ckf splicing
    how do you properly splice a 2 wire ckf to a 3 wire ckf....
    this is on a ek b18b swap.
    please dont respond with ckf trick since it will still throw a cel.
    Jul 2009
    ckf trick^^^^ or bypass whatever you wanna call it..... im looking for actual splice info there are two grounds one shielded and one not can i integrate them together????
    SOUTHSIDE
    ive done the bypass trick several times and it removes the check engine light
    recheck your codes it might be a different code it throwing
    Jul 2009
    ok k kay
    Jul 2009
    well got my swap wired up.....
    figured out all the plugs and shit and she runs perfect so far. as for the ckf....... pretty simple i stripped apart the grounds matched the colors up (at connector and before plug on harness), soldered the wires and connected the grounds to the metal wire insulation (kinda like coaxial wire). work great.
    i didnt have to change any plugs or repin the ecu..... i guess thats all just b18c swap stuff idk.
