Results 1 to 14 of 14
Thread: Integra 90 wont start!!!
    B Powered Mik2006's Avatar
    North Side
    Default Integra 90 wont start!!!
    I got a 90 teg now that wont start. theres no clicks and we just changed the starter. any ideas? it will push start tho.
    cars
    integra 90 ls
    integra 92 gsr b20v turbo
    integra 00 ls
    infiniti i35 02
    somewhere, GA
    have the battery tested...sounds like it doesn't have enough power to engage the starter....
    check terminals, grounds, etc.
    '82 TE72 SR5 Sport Coupe
    3tc
    West palm beach
    battery or ground, loose wire maybe...
    NO ADVERTISING
    -IA MANAGEMENT
    Aug 2009
    Lawrenceville, Georgia, United States
    check your ground on the starter. try hitting the starter while your starting it
    North Side
    but the starters brand new. but ill check to the other ends of them. any other ideas?
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
    Quote Originally Posted by D3UC3S
    Quote Originally Posted by AyO Deebo
    thats it
    Quote Originally Posted by Mik2006
    check those first 100% sure u got something fucked up
    somewhere, GA
    Is your main relay clicking as it should when you turn the key?
    3tc
    Clutch switch?
    Alarm?
    Prolly loose wire or ground. I was thinking dizzy but if it push starts nvrm. Just check those wires
    damn, i want that penis
    Thats right.. A-ran's Avatar
    More than likely it is a problem with the small plastic stop that depressses the clutch switch these are very common and you can put a bolt and nut in place of it.
    Hope it helps
    Quote Originally Posted by A-ran
    Hope it helps
    rubber , they are rubber lol...after years they turn into hard ass plastic lol....
    But correct bolt an nut easy fix..
    AccuracyPerformanceAutomotive
    Hope it helps
    x2. lol, just fixed an Accord with a nut and bolt on the clutch switch.
    500whp of spinnin fury!!!
    North Side
    ok well i know the starter works because i connected the possitive from the battery and connected it to the starter solenoid terminal and it started. now i just need some ideas on how to find the grounds from there on.
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
    Did you look at the clutch pedal switch???
