is engine swap fast? also, does anybody knoes how to do it? and how much would you charge?
"Bacon And Cheese"
We can do any swap you need. Let me know. 678-363-6789.
And what do you mean is an engine swap fast? Can it be done fast, yes. and Depending on what motor it can be quick .
more info dude.
What car and what swap?
sorry for a 1995 acura integra. Ls motor. take out and put another one back in.
Originally Posted by Arm&hammer
"Bacon And Cheese"
2-3 hours average....
to take the old one out and put a new one in there? also, it would be nice if i get a brief summary on how to do it.
Originally Posted by wrekonize
"Bacon And Cheese"
unbolt the old, put it, drop in the new, and bolt it in.Originally Posted by BAC
can you explain that in a easier way.
Originally Posted by Barefoot
"Bacon And Cheese"
pull old install new. simplest it gets.Originally Posted by BAC
take axles out
unbolt linkage, exhaust, ps, ac
unbolt motor
take trans off
put trans on new
bolt everything back up
If you never done it before, then take it to someone that knows what they're doing. Either that or pick up a helms manual and start reading.
where are u located?
Why would he take trans off and put new trans on for a motor swap? Why you got to change the trans?Originally Posted by NoWAyItZTOMmY
Back to being stock and slow
if its a manual he is correct trans will have to come out or be dropped.Originally Posted by Motivation
it's pretty damm easy, It's like taking candy from a baby only if you have all the necessary tools
you'll need
10mm
12mm
14mm
17mm
19mm
32mm for your axle nut
pliers for some stuff
needle nose
axles comes off
rear mount
passenger side mount
driver side mount
ac side mount
tranny side mount
3 plugs harness side of passenger
3 plugs harness on driver side
3 ground wires, tranny & valve cover, near thermostat housing
knock out the gator tooth that holds the shift linkage i use a 3/16 to knock it out with hammer & 12mm
take off 2 12mm bolts that holds the slave cylinder
header to catback bolts believe it's 14mm 2 of them
take out radiator, for more room to work
and them boom boom poWW engine hoist that bish out and take off
you should be able to knock this out in 2-3 hrs 8D
/Oo ___A___ oO\|=_/_______\_=|
