Results 1 to 18 of 18
Thread: h22a problems
    IA Senior Member ballt85's Avatar
    blairsville ga
    Default h22a problems
    car goes in gear when off but not when runnin anyone now what this might be
    2000 civic ex (current)
    00 Subaru 2.5rs (gone)
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    91 cb7 h22a (remodeled)
    2.0vtec
    Snellville, GA
    that sounds like it could be the clutch. if you are not having any issues with clutch hydraulics, then most likely you will have to drop the transmission and check the clutch disc.
    Mahdavi Motorsports
    770-923-1550
    04 S2000 Turbo
    NDRA turbo 6 champions
    Nations fastest auto mkIII Supra
    ^^^^pretty much
    blairsville ga
    fuck i was prayin nobody would say that
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    known as Charles
    Check all the hydrolics of the system first before pulling the tranny. Look under the dash and see if the clutch master cylinder is leaking. Also, check the boot around the slave cylinder to see if it is leaking. Good luck.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    blairsville ga
    the clutch ingages fine all fluids are full all shift link are movin fine
    Quote Originally Posted by Main Stream
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    no photo skills....
    Jul 2009
    senoia
    check the throw out bearing
    blairsville ga
    its just stop workin all of a sudden throw out bearing would have made a some sort of sound
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    Sounds like a clutch issue
    blairsville ga
    thats what im thinkin
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    Senior Member StreetHazard's Avatar
    Sep 2008
    I just got my prelude out of the shop last week with this exact same issue...the (main shift fork) was broken, with caused it to kick off the throwout bearing...disengaging the clutch. may possibly be a manufacturers defect. I found this online but its for the 5th gen prelude 97+ H22A4...but it happened to mine a 1995 prelude JDM H22A with a USDM tranny
    Trouble Spots
    Consumer Guide'sŪ Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
    Dashboard lights: The active torque transfer system (ATTS) light may come on and the system will shut down. A revised control unit is available to replace the original one. (1997)
    Dashboard lights: The malfunction indicator light comes on because the transmission-control module is damaged by electrical spikes from the ignition switch. (1997)
    Manual transmission: Because of a manufacturing defect in the shift fork, the transmission may grind going into fifth gear. (1997) OR FUCK UP COMPLETLY
    Oil leak: Sudden oil loss and resultant severe engine damage could be the result of front balance shaft oil plug popping out. (1997)
    Seatbelts/safety: The button on the seatbelt that prevents the male half of the buckle breaks, and the buckle slides down to the floor. (1997-98)
    Transmission problems: Failure of manual and automatic transmissions may be covered under extended warranty up to 7/100,000. (2000-03)
    Vehicle noise: The rear corners of the headliner rub against the rear window causing a rattle, especially on rough roads. (1997)
    Vehicle noise: Rattles or buzzing from under the car may result from the heat shield being too close to the active torque transfer system (ATTS). (1997)
    blairsville ga
    so it maybe the shift fork huh
    Quote Originally Posted by StreetHazard
    Trouble Spots
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    Sep 2008
    quite possibly....but you have to take the tranny off to find out, im sorry man, if you are positive you have hydraulic pressure then its very possible, especially If recently you know your clutch has not been slipping and is still good
    I wish it was just a simple fix
    If I can offer you any good news (if it turns out that is your problem) a main shift fork OEM from the honda dealership was only about $50, but I would suggest replacing your throwout bearing since you will be in there anyway (even if it appears to still be in decent shape)
    blairsville ga
    tea the clutch hasnt beem slippin its only bout six mnths old i just didnt want to drop the tranny
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    Sep 2008
    Quote Originally Posted by ballt85
    I didnt either....sorry man
    blairsville ga
    well thats suxs
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
    VTEC Killa!! 99' LuDe's Avatar
    Warner Robins,GA
    have you looked at how much clutch fluid you have??
    1999 bb6 rip 1998 dc2 sold 2003 ep3 totaled 1999 em1 ftw
    blairsville ga
    yea its full if i jack the car up and slowly put it in gear it will go but the tires are spinnin even with the clutch pushed in then when i hit the brakes car dies so!!!!!!!idk
    Quote Originally Posted by 99' LuDe
    94 civic ex (sold)
    00 cbr 600 (sold)
    91 cb7 h22a4 (sold)
