Thread: civic swap help again....
    roberta
    Default civic swap help again....
    car is 94 civic dx with obd1 ls swap....while i was swappin there was a freakin down poor and i had the hood off,water seemed to seep into the spark plug hole and was all in the wire boots.so when i got up the next mornin i blew all the water out and it started up fine but after a few minutes at idle it started runnin rough and smelt of raw gas...and now it wont start any help will be rewarded with reps
    AccuracyPerformanceAutomotive
    It may have took the resistance in the wires way up, being saturated for so long and burnt the coil in the dizzy. Check to see if it is sparking.
    500whp of spinnin fury!!!
    roberta
    Quote Originally Posted by QWK D16
    should i check the wires at the dizzy or the dizzy itself
    Quote Originally Posted by jcs
    Use a spark tester first to see if spark is gettin through the wires. If not then the problem is inside your dizzy.
    sounds like what got into your dizzy!
    roberta
    is it possible it f***** up the dizzy or just the coil...
    Usually you can see a burnt spot down the coil. But its possilbe the ignitor is bad.
    roberta
    so i go outside today and the bitch fires right up,checked and say im gettin spark from my dizzy to my wires.then i proceed to take it for a test drive and it seems to sputter or fall on its face under throttle or light load...spark plug or wire possibly??
    More than likely its water inside the dizzy, but it could be a wire. Is there water down inside anyone of the spark plug tubes??
