Results 1 to 24 of 24
Thread: over heating problem
    stockbridge ga
    Default over heating problem
    my 88 323 gt is over heating.
    its got a new thermostat, Tstat gasket and i had the radiator "rotted out"
    and its still over heating off and on
    i can break boost it and it doesn't heat up
    but if i creep to a stop it heats up(the fan STAYS on)
    the manager and the shop guys all said to get a new CAT and a new muffler(dollar bill size hole in the muffler)
    does the new exhaust make sense.
    if so would it be worth the extra $ to go ahead and get a 2.5 from the turbo flange back?...
    chuck-norris-a-souris
    stockbridge ga
    reps for advise
    does your cooling fan come on.
    Now you see me...... rbsilvia's Avatar
    ??? can you not read??? He said the fan STAYS ON!!! lol
    Quote Originally Posted by rbsilvia
    take that shit someplace else. last i checked u havent done shit around here. u dont know shit. since your so fuckin bright whats his issue. repped
    stockbridge ga
    getting a 2.5 today.
    ill keep yall updated
    General Tech Hater
    no offense, but the exhaust in no way should make the car overheat..
    when was the last timing belt/water pump done?
    and as for rbsilvia, stfu and gtfo.. the OP said the FAN comes on, maybe you know of a handful of cars in the world that are front engine front wheel drive and dont have a seperate cooling fan/condensor fan..
    Official "Delete the clubs/crew section of IA" Member #1
    Quote Originally Posted by chouston86 View Post
    So this is how it goes down when I beat you I want the cash and the respect. To some people thats more important. Sounds familiar?
    stockbridge ga
    Quote Originally Posted by MidLifeCrisis
    16 days ago.
    the car is GLOWING hot from crud in it...
    stockbridge ga
    update
    the new exhaust didn't do a thing but make it sound good
    im thinking it a water pump tho.
    cause at a idle its fine but when speeding up or even on the gas a little it begins to heat up.
    Push in the clutch and it will slowly cool back down.
    im thinking the the shaft or spindle is or has breaking loose from the propeller or fan that pushes the water through the motor... make since?
    responces?
    im pretty sure its your water pump just a first thing that came to mind type deal its always good to replace when you replace the timing belt
    J.R
    Down South
    going with water pump also
    stockbridge ga
    Update
    new pump
    hoses
    rotted out radaitor
    new tstat and sensor
    but still overnheating
    it wigging me out now
    up until it gets too hot it pulls hard
    and just before it will spudder a little but the car won't shake
    it's like the wastrgate is wide open cause I can hear the boost build up
    it this point I fucking clueless
    but the only thing left is a headgasket
    TR C5 Z06 Whiteboy572's Avatar
    Northside
    just a common response. You did make sure all air pockets are out, bleader valves (if any?) open? Heat works in car? I would say try a new radiator. A head gasket will make it sputter though. Is there white smoke coming out of your exhaust? Whats your oil look like after running it? Milky? If so you have a bad B.H.G.
    Block test FTW
    www.jjspec.com Macon, Ga
    Air pocket or most likely head gasket. Sorry you are having an aweful time.
    Middle, Ga
    Damn, bro. Hope you figure this shit out. I know the feeling.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    stockbridge ga
    block test?
    should i get a comp test and a leak down?
    A block test can check for exhaust gasses within your coolant with the vehicle running, is VERY accurate at determining blown headgaskets with cooling problems.
    stockbridge ga
    ohhh....
    Learn something new everyday
    is it pretty simple do use
    Very easy. Remove your rad cap and it sits where the cap goes. The one i've got hooks up to a vacuum line on the engine. The fluid inside will change color if it detects exhaust gasses.
    stockbridge ga
    update:
    today i let the car warm up like usual
    and i waited a little longer to see if it would smoke.
    and it did
    just once but it was a PLOOM of white smoke
    but im still going to do a block test
    do it or a comp test and let us know
    stockbridge ga
    wHat are the odds of my block being cracked
    hard to give odds. if u do the tests ull know. pm sent
