Results 1 to 26 of 26
Thread: Car bogs out in every gear
    southside ATL
    Default Car bogs out in every gear
    all of a sudden my car threw a code of p0420 Catalyst System Efficiency Below Threshold (Bank 1) and two codes for an o2 sensor. I checked for exhaust leaks, none. Im not sure if the catalyst could be clogged? it drives fine but when u try to mush on the gas it bogs but when stepping on the gas pedal lightly it will drive normal? Whats the deal? Btw: there is a little smell coming out, i remember that smell when i put the new cat in a few months ago.
    somewhere, GA
    few months wouldn't be long enough for the cat to go bad....maybe it was defective from the start. What kind of cat did you put on?
    '82 TE72 SR5 Sport Coupe
    3tc
    southside ATL
    Quote Originally Posted by D3UC3S
    some autozone junk. it was brand new though
    PROJECTjdm project_EM1's Avatar
    Stockbridge, GA
    could be misfire check your plugs and wires
    SoLow OutKast
    92 Civic Lx Ferio - sold
    94 Civic Dx Eg- insurance totaled
    93 Civic Si Eg6 - stolen/and striped(f**king thieves)
    00' Boosted Milano Red EM1- DD
    southside ATL
    Quote Originally Posted by Nfamou5
    checked that, no codes thrown for that, and listend to the exhaust, sounds steady, no popping
    Stockbridge, GA
    Quote Originally Posted by j0natell0
    mine wasnt throwin a code for it either until i replace my cat
    does it bogs or does it stutter if it bogs try cleaning your egr
    if it stutters check your plugs and wires doesnt hurt to check anyway
    SoLow OutKast
    somewhere, GA
    Also check the fuel filter....may be time for a new one since it only does it at WOT.
    3tc
    i think your running lean. the smell from the exhaust can u describe it.
    southside ATL
    cleaned out the fuel filter, checked the spark plugs they give out spark, check the timing. its good. i cant really describe the smell. but its still bogging..
    Norcross
    dont forget to mention we hollowed out the cat today
    y yall do that. now he needs a new 1. should have just unbolted it.
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    I had the same issue with an Integra I bought a few years ago, the cat was indeed clogged. If the engine burns oil, or the A/F mixture is off, added to the fact that it is a cheap aftermarket cat, it will clog up VERY quickly. The easiest way to find out is to just remove the cat and exhaust and test drive the car. It will be very loud, but you are just looking to see if the condition stops. If the car feels a lot stronger (which I'd bet money it will) then you need to replace the cat, and correct the problem that is fouling it in the first place. Like I said, I would look to burning oil because of worn rings or valve stem seals, or both. Try it, it costs nothing but an hour or so. Good luck.
    Edit: the smell is also most likely a rotten egg or sulfur smell, which is attributed to the catalyst overheating. If it is severely clogged, you will be able to drive the car and then immediately look at the cat under the car, they can get so hot when clogged they actually glow red!
    Who knows?
    somewhere, GA
    and get a magnaflow HI FLO cat.....dont just bore one out. Thats askin for crap like this to happen
    3tc
    southside ATL
    it bogs in every gear, it doesnt stutter. just feels like its not giving power. what should i do next
    southside ATL
    sorry let me explain it a little better. When i crank the car the rpms will jump to 1k. feels like a dead startup. then the rpms will jump up, then down to the point it sounds like it will stall and die. Then it will idle fine.. The car bogs when pressed on the gas all the way. Drives kind of normal, but when heavy accelerated it bogs.
    Suffolk, VA
    Compression check ASAP. If it sounds like you don't have compression.... you probably don't.
    Who knows?
    Certified Gearhead Mr. Antonov's Avatar
    Check your idle control valve vacuum hose.
    southside ATL
    still acting up
    Suffolk, VA
    What were the compression numbers?
    Who knows?
    AccuracyPerformanceAutomotive
    Check the vacuum to the MAP sensor and make sure the dizzy is ok. We also had the same problem with an older DA with a b20 swap that had a bad TDC in the distributor.
    500whp of spinnin fury!!!
    Stay Humble
    WV
    20$ says its you 02 sensor.....checkem out
    Quote Originally Posted by chaseamundo
    $20 says it's not the o2 sensor
    i might have had a similar incident like this once on my car, and night this same incident happened and my header was glowing red, and found out it was my cat convertor it was clogged... and i ended up gutting my cat convertor .. since we i live dont do emissions 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    southside ATL
    timing slightly off
    Stay Humble
    WV
    youknowit my be on to somthin haah
    FREE BUJU StarBwoy's Avatar
    IDK
    didt you wash da motor same thing happen to my bros da water got in da plugs
    went looked at it yesterday. his timing on the exhaust cam off by atleast 2 teeth.
