Results 1 to 22 of 22
Thread: HID kit question
    Default HID kit question
    First off I want to put an HID headlight on my ATV. It can run up to two 35 watt halogen bulbs off the stator... but thats the issue, it only has a stator. No battery. Therefor the headlight gets brighter/dimmer with the throttle. An HID bulb/ballast can't take that abuse can it?
    BMW 750iL
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    er..the Starter?
    And no.
    Why in the world would you want HIDs on an ATV? Total overkill.
    What kind of bulbs does it take, and what brand are you using?
    Correct Fitment Crew CEO
    Quote Originally Posted by XanRules
    er..the Starter?
    And no.
    No, stator, just like I said. http://en.wikipedia.org/wiki/Stator
    And because it has one headlight and gets a lot of night use?
    BMW 750iL
    Hiawassee, GA
    Headlights on a quad are straight homo.
    -Zach-
    1987 Toyota Pickup - Toy
    Quote Originally Posted by 03RCode
    Gets a lot of use at night, so it is needed.
    BMW 750iL
    Dining in Hell
    in any case, no, you can't do this without a battery. You're better off buying very bright, nice bulbs. Like Osram Nightbreaker +90's, GE NightHawks, Philips VisionPlus, or even some decent HIRs.
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    I would take a look at whatever HID ballast you are considering and look specifically at the voltage range it will need to operate and go from there. If it has a fairly wide range of operable voltage, it will probably function fine, albeit the ballast and bulb's life may be decreased some. try www.ddmtuning.com or www.starrotor.com since they sell pretty affordable kits in singles. you could also go ahead and get a kit for 2 headlights so you already have a backup on hand. Ignore everyone who isn't helping simply because they feel the need to chime in without knowing the answer.
    Who knows?
    Dining in Hell
    I was trying to be helpful :\
    I have looked at some kits but I can't find any info about the ballast such as that. I looked before posting the thread, do you know of any kits that have that info on the site?
    BMW 750iL
    Suffolk, VA
    I'll search around and see if I can find the info again, when I was looking for an HID kit for my motorcycle I came across it. I was mistaken on one of my websites, it is actually www.starrotors.com
    Who knows?
    Looks like most are 9-16v from what I gather.
    BMW 750iL
    Suffolk, VA
    Quote Originally Posted by X-Runner
    I imagine that your stator can stay pretty well within that range, you should be ok. best bet would be to hook a DMM to the output of the stator and measure voltage at idle, then rev the engine and see what it peaks at. Compare results with aforementioned range, and boom you have an answer. I would also guess that the voltage is most critical in the first few moments that the lights are on while the arc is being ignited, after that the ballast is probably pretty resilient.
    Who knows?
    Quote Originally Posted by hondabuilder
    Ill check it out and see what the ATV ranges from then. So you think either riding or keeping the revs up some when turning it on should be ok?
    BMW 750iL
    Bender A. Rodriguez
    Macon
    Its not that easy. You have to remember that each bulb, even a very efficient one is going to pull over 4 amps each, and 6-8 amps on start up. Most stators can't support that kind of amperage and still keep around 12 volts. If you try to run it off the stator alone it probably won't ever strike. You really need a battery or something to stabilize the voltage or the ballast won't last long. They're pretty picky and need pretty stable voltage or they'll burn up, going up and down like it will off the stator alone will only cause problems. With a battery in the system you can certainly run them.
    Ryan Reynolds
    Dunwoody/Sandy Springs
    How about some fog lights?
    It has a perfectly fine, working headlight. I want to know if an HID setup will work, thanks!
    BMW 750iL
    Suffolk, VA
    Most likely. Your mileage may vary
    Who knows?
    Hmm well a battery is to heavy and getting to expensive for my taste. Oh well.
    BMW 750iL
    Bender A. Rodriguez
    Macon
    A decent car stereo capacitor should work too, much lighter and you can probably get one pretty cheap.
    Ryan Reynolds
    All you need is to buy a small lawn mower battery that is 12 volts. Then connect the HID kit directly to the battery via HID Relay. The relay will allow you to trigger from the harness. This way the battery will supply the power 100% and the harness would only supply power to the breaker in the relay to turn on or off.
    FYI...O' Reilys has betteries for cheap. I bought a full sized one for like $49.
    Suffolk, VA
    or if weight is the primary concern, and price isn't as much, you could look into an odyssey or braille battery, they are very light.
    As with anything, you gotta pay to play.
    Who knows?
    Top Notch
    Macon
    I love the hid on my 300ex helps alot at night.
