Thread: Compression test number on a 97 integra gs
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    Default Compression test number on a 97 integra gs
    1. 190
    2. 175
    3.180
    4.165
    125k mileages on my b18b1
    is it bad??????
    NIKON Squad member 05
    Mah shit thread
    They say no more than 15psi variance between cylinders, but i wouldnt really be concerned.
    southside
    yes i have to checked because water went in my engine last night. i accidently drove into the paddle. Im scared about the rod bent.
    Mah shit thread
    Is it running rough or misfiring ?
    southside
    its running normal. I did change the oil after my motors shut down (hydrolock) last night.
    Mah shit thread
    I mean its a little out of spec but that could even be rings or how the test was taken. i probably wouldnt worry about it. with a bent rod i would expect a much greater variance in compression. when you started it back up, did you remove the spark plugs to clean out any water, or did you just crank and go?
    with those comps as long as its running good i wouldnt worry. had 1 said 90 i would.
    L'ville
    put some marvel mystery oil on top of those pistons and let it sit for a bit, other than that it looks ok
    southside
    thats weird because i saw milky in the oil before i change oil but my motors running normal. I guess im lucky?
    Mah shit thread
