Results 1 to 11 of 11
Thread: Wiring Help--0bd1 b18c1 in a 97 ek hatch
    Wanting Boost! rsxappeal's Avatar
    Default Wiring Help--0bd1 b18c1 in a 97 ek hatch
    Hello, before i start trying to make a harness or buy the ecu i need, i just want to hear your experiences and advice first. I have a 97 ek hatch non-vtec, just picked up an obd1 b18c1. the only harness i have is my civic one, but i can pick up the gsr harness if i need to splice the two together or something. Which ecu should i run? also is it even possible to pass emissions?
    add vtec wires to your current harness. ecu not sure. emissions is passable.
    EF Squad
    i believe you have to use a gsr ecu cus it has the vtec features otherwise vtec wont kick in. Also u will need a jumper harness as well cus ur car is obd2 and u got a obd1 motor so it is best to convert everything to obd2. GL!
    Unpainted EM1 Zhu's Avatar
    if you're going from obd2 to obd1, I think (don't quote me) but I think it's not possible to pass emissions since you're going backwards in terms of diagnostics
    WTB: Driver's Side Sunvisor for 96-00 Civic
    yeah i know having the obd1 ecu in my obd2 car is an automatic emissions failure when they try to hook up to my port b/c it won't read. So, Zanget you are saying to put an obd2 distributor, alternator, injectors, etc on my engine and use an obd2 gsr ecu?
    EF Squad
    Quote Originally Posted by rsxappeal
    yup most important is the ecu and distributor, u cant mix match it. If u gonna stick to obd2 u gotta keep it all obd2. And yes it will be better off for u to convert everything to obd2.
    well if i have it all obd2 i guess i would use an obd2 ecu, but there not tuning friendly? Also, what if i keep all obd1 parts and just use distributor conversion harness and stuff and use obd2 ecu? Would that work?
    Use the obd1 ecu. You won't pass emissions anymore, so make a friend that works with emissions quick. You can keep obd1 parts, just gotta rewire them. Rewiring the alternator is quick (there's a write-up for it online), for the distributor, just buy the conversion harness, it's $25 and saves time, lots of it. Rewire your injectors if you wanna use the same injectors that are already in the motor. I've heard d-series and b-series injectors are the same, but i'd just rather use the ones that were already in the motor. And don't forget the ecu jumper harness. It's about $75 from rywire. And of course, wire in vtec. I believe a few other plugs are different as well, but I can't remember off the top of my head
    West palm beach
    iif your not going to be building and tunning, then keep it obd2....
    well im going to get a nice header, intake manifold, intake, for the swap. nothing internally right now, like cams yet. So, i'll need the obd1 ecu i guess to tune it. Alright thanks.
    AccuracyPerformanceAutomotive
    You could convert your ecu and distributor to obd1 with a jumper harness, and when emissions time comes put everything back to obd2. That way when the time comes to tune it for more power, you can use obd1 and a p28, which is alot easier than obd2.
