Results 1 to 37 of 37
Thread: Tearing my RB25DET apart
    Oviedo, FL
    Default Tearing my RB25DET apart
    Had a miss in #6 cylinder. Pulling it apart to replace the rings.
    Attached Thumbnails Attached Thumbnails -p1020233-jpg   -p1020231-jpg   -image001-jpg   -p1020239-jpg   -p1020240-jpg
    Oviedo, FL
    more
    Attached Thumbnails Attached Thumbnails -p1020242-jpg   -p1020243-jpg   -p1020244-jpg   -p1020245-jpg   -p1020246-jpg
    Oviedo, FL
    more pics
    Attached Thumbnails Attached Thumbnails -p1020247-jpg   -p1020248-jpg   -p1020249-jpg   -p1020250-jpg   -p1020251-jpg
    Oviedo, FL
    few more
    Attached Thumbnails Attached Thumbnails -p1020252-jpg   -p1020254-jpg   -p1020255-jpg   -p1020256-jpg   -p1020257-jpg
    Oviedo, FL
    last set, ran out of time to finish
    Attached Thumbnails Attached Thumbnails -p1020258-jpg   -p1020259-jpg   -p1020260-jpg   -p1020264-jpg
    looks like a lot of work bro..good luck.
    Oviedo, FL
    Thanks, just got to pull the head off tomorrow and then repeat the process
    Oviedo, FL
    Got the rest of the motor pulled. Picking up another RB25 tomorrow then going to rebuild this one for high hp
    college park
    Why get another rb25? How much is the difference in hp from the rb26? I would think you would get that instead
    now with LSD
    college park
    Thanks for the first pic I have a new screen saver for my itouch
    now with LSD
    Oviedo, FL
    It's only costing me $500 where as a 26 swap would run me in the hole hard core. Plus my goal is to be a beastly GTS killing GTR's
    Bender A. Rodriguez
    Macon
    Why in the hell did you pull the head just to pull the motor? Seems like an awful waste of time.
    Ryan Reynolds
    Oviedo, FL
    I was unsure of the approach I wanted to take about the low compression at first and then I found a replacement motor so I ripped the rest out
    Bender A. Rodriguez
    Macon
    I'll tell you, any time you're wanting to do anything that might involve taking the motor apart its easier to just yank it. Nothing is easy to do with it still in the car. And when you put everything back together do yourself a favor and use proper metal exhaust/intake gaskets and throw those sintered metal POS's away.
    Ryan Reynolds
    Oviedo, FL
    New motor is in, took a little longer then I thought with the motor mounts and it got really cold tonight so I bolted it down and will finish the rest tomorrow. I'm shooting to have the majority of it done by noon give or take between work hours.
    IA MEMBER Killswitch Performance's Avatar
    Nice, but I found a couple things funny.
    Like CCR mentioned, why not just pull the motor to begin with? You said you were replacing the rings, which mean disassembly of the bottom end. So why not just pull the motor to begin with?
    Secondly, why did you have to label the oil line for the turbo? Where else would you put that? Haha.
    Anywho, props, looks good man.
    Tyler
    Oviedo, FL
    I was not expecting to pull the entire motor and replace rings at first sight, I was attempting to see if the rings were stuck and needed to be freed up while I cleaned things up a bit.
    I like to label everything. I wanted to make sure everything was labeled just incase it ended up taking a long time to do it or there was problems, I don't want to forget where things go.
    MCD
    good job. very organized and clean
    Oviedo, FL
    New motor is in and running, just need to do a little street tune and work out a few things here and there.
    Miss my Civic.
    Reps for having big balls and doing it in your driveway.......while using wheels as jack stands. Dont get much more bad ass than that.
    Oviedo, FL
    lol thanks, I was kinda iffy at first about the wheels but then I got comfy with it and was all up under there.
    San antonio 210
    Nice work. Saw this on INC...
    Oviedo, FL
    Thanks, working on the tuning right now. Power FC is pretty confusing and got some fuel issues. My injectors are pretty much just pouring fuel into the motor non stop, I can see my gas gauge dropping as my fuel leaks out the exhaust.
    Oviedo, FL
    Car is now sitting at National Speed in Wilmington NC, keep the fingers crossed.
    Latest update,
    Got a call today and they did some magic on the cylinder walls and a few other things, http://www.youtube.com/watch?v=R7BEGsZkkUs
    Should have it on the dyno for some more troubleshooting and tuning tomorrow.
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    nice, really nice
    shazam.. s2k kid's Avatar
    Paulding
    sweet skyline man....good luck
    Oviedo, FL
    Thanks, it's going on the dyno tomorrow again to shoot for 400. Here's my full build up thread
    http://skylineownersusa.com/forums/s...ead.php?t=3304
    MCD
    numbers?
    Oviedo, FL
    350 15psi stock internals and shitty charge pipes. Putting my HKS cams on and getting fatter intercooler pipes fabricated to increase the numbers safer before pushing over 20psi
    Quick update
    Last dyno pull...
    Test Drive...
    350whp @ 15 psi for now
    Pics at Deals Gap this past weekend, we had a total of 7 Skylines show up
    http://www.photoreflect.com/pr3/orderpage....526&po=1526
    http://www.photoreflect.com/pr3/orderpage....0753&po=753
    Senior Member Maki's Avatar
    Alpharetta
    reps for labeling shit on the disassemble, this is a practice raely seen anymore.
    Oviedo, FL
    Thanks, I tried to keep things barney style just incase I ran out of time and had to set the project aside for awhile. Been there done that and don't care to do it again, to many lost parts and messed up lines.
    Quote Originally Posted by Type-R
    awesome job!!!!!!!!!!!!!!!!!
    Oviedo, FL
    Thanks, here's 2 new pics
    Attached Thumbnails Attached Thumbnails -lights-jpg   -lights2-jpg
    rock da sohc
    loganville
    so how did you come across a new motor for 500$$$ or was that just the block??
    Oviedo, FL
    Full motor,
    super duper hookup price
    rock da sohc
    loganville
    your tellin me... next time you can get a deal like that or even close hit me up.... plans for ma 24ay... lol....
    m5
    alpharetta
    clean work bro ... +1 for u sir...
