Results 1 to 30 of 30
Thread: front of car starts to shake when slowing down?
    Gwinnett-Grayson
    Default front of car starts to shake when slowing down?
    i am trying to figure out what this could be. the only thing i can think of is its either the axels, the rotors, or the pads. hopefully not something else. anyways, when i go from a higher speed to slow down to either stop or take a turn into somewhere. it rattles/shakes. i dont know what it could. anyone have any ideas? god i am hoping its nothing serious!
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Sounds like a rotor pulsation.
    Gwinnett-Grayson
    what does that mean? i figured it might have soemthing to do with the rotors or something. but im not sure.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Where Am I
    Yea I would check the rotors first thats probably it, u probably warped them......
    Gwinnett-Grayson
    i was thought that but i wasnt to sure.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    It means that you should try to re-surface the rotors.
    Gwinnett-Grayson
    i see. well ill look at them on sunday i guess. im just hopin its nothing more serious then that.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    a complete brake job will fix that. rotor new or turned if able to be, and pad. make sure to grease the slide pins.
    Gwinnett-Grayson
    i was thinking about doing that. but i am not really sure how to do it. is there any how to's or anything that i can look at.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    :noitacoL
    yeah man check on www.honda-tech.com you should be able to find all your answers on there for tech related issues
    Gwinnett-Grayson
    appreciate it Guy.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    i'm a got dang wallaby!!
    davison....... don't die. get NEW brakes.
    Quote Originally Posted by blacknightteg
    u serious dont know how to do brakes.
    make sure your wheels are tight lol
    and if it only shakes when applying the brakes then yes rotors are warped...if it doesnt it without using the brakes then maybe a axle but it would do it on hard accel also....Best of luck
    Super Handling
    Can't rule out crap tires!
    Gwinnett-Grayson
    dude i dont work on my car like that
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    ALL CAPS JITB's Avatar
    id consider this being your first project.. to get familiar.. brake job on a honda is as simple as it gets! The only tricky part is bedding the brakes when your done.. but even that is a basic process. or pay me to do it...
    to change a rotor and pads he wont need to bleed the brakes.
    alldata
    1. Raise and support front of vehicle and remove wheels.
    2. Remove caliper pin bolt, then pivot caliper up away from rotor.
    3. Remove brake pad shims and pads, Fig. 2.
    4. Clean caliper and inspect for excessive wear or damage.
    5. Install pad retainers, then pad shims and pads, Fig. 2.
    6. Back out bleed screw <--( i normally skip this step on most cars) and push in piston to allow caliper to fit over pads, then tighten bleed screw to specification.
    7. Pivot caliper into position, then install pin bolt and tighten to specifications.
    to get the rotor off just take the 2 bolts holding the bracket for the caliber off. then the 2 screws that hold the rotor to the hub.
    bedding! not bleeding If he dont do that right, hes gonna be wobbling by the end of summer all over again!
    i thought u made a typo.
    hustler ksniperfox's Avatar
    lawrenceville
    haha first time i did my hondas brakes i forgot to mash the brake pedal until it got firm before i took a test drive......
    self explanatory........that was a fun test drive.
    dont forget to mash brake pedal after youre done with rotors/pads, until it gets firm.
    just get a haynes manual. if its your first time it shouldnt take more than like 2.5 hours. and thats being fairly generous. all you need is a lug wrench, jack and stands, screw driver, couple sockets and thats it. oh and maybe a hammer for those rusty old rotor screws.
    West palm beach
    Quote Originally Posted by ksniperfox
    good advice found here...
    Gwinnett-Grayson
    where can i get a haynes manual? or is that a stupid question? im just trying to learn slowly so bare with me please!
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    J.R
    Down South
    re-surface um dog
    J.R
    Down South
    haynes manual = autozone
    J.R
    Down South
    there no such thing as a stupid ? dog ,thats wut this thread is about
    earth ????
    alldata
    well said !
    Where Am I
    Quote Originally Posted by NOCLUE
    ^x2 best things made
    IA Member dc 4eva guy's Avatar
    Carrollton
    check your lug nuts, and mostlikely one or both rotors are warped
