Results 1 to 35 of 35
Thread: vtec wont pop! help me!!!
    Senior Member honda4life's Avatar
    macon
    Default vtec wont pop! help me!!!
    ok i just got done putting my b16a in my 93 civic.....vtec will not pop......i have done everything that i knew and still nothing? just wanting to c if anyone knew of any othere reasons why it would not be working..thanks
    <a href="http://www.mybannermaker.com" target="_blank"><img src="http://i.imgur.com/9sjGr.jpg" alt='Create your own banner at mybannermaker.com!' border=0 /></a><br>
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    what have you checked? there's alot of things that'll cause vtec not to engage.
    cel?
    did you check your vtec fluid?
    earth ????
    lmao daaaaamn
    just fucking with you. did you try your vtec solenoid? maybe the plug is not in or its not hooked up right. your timing might be off? im just throwing random ideas out there. list al the things you have tried.
    also what ecu are you running?
    한 국
    trace the wires back to the ecu
    Athens/ATL
    Most obvious question... did you let the engine come up to normal operating temperature? VTEC has an idiot-proof feature of not engaging until the engine is warmed up.
    yup yup
    also check
    wires make sure they are going to the right pin on the ecu
    oil pressure not enough oil or pressure will stop it from engaging
    clean the screen on the solenoid
    macon
    ok thanks guys...i have tried changin the pressure switch vtec solenoid....runnin the wires straight to the ecu..checked them 100 times...lol....i have tried everything!! it did pop once but thats it....im lost, is there anything else?
    resize pic
    adjust the flux capacitor, lol just fucking with ya. maybe pm vtecidd he knows everything about hondas.
    i drive slow im_hung's Avatar
    location, location
    warm up ur car. then manually engage vtec at idle... ill get you the info on how to do that when i get home. basically you jump the vtec connector. ull know vtec kicked in b/c your idle will be wayy off...
    Where Am I
    Quote Originally Posted by mikegsr
    X2^ on that, and make sure u have no check engine lights, your speedo has to work for vtec to work, and I know someone said check your oil pressure but also just check the level too(low level, lower pressure).....
    DC5-R
    Gwinett
    check your oil
    Senior Member 4DrTeg's Avatar
    Quote Originally Posted by IntegraXTR
    check your oil
    x2
    http://www.honda-tech.com/showthread.php?t=830163
    if that dont get u going u got some serious problems.
    Dec 2008
    Cobb
    im haveing the same problem in the 95 GSR motor i just dropped in my 94 civic. ive seen so many differnt things people say i have to wire but idk how realiable the info is, can someone tell me since we're on the topic.
    if you have low oil in your continueum transfunctioner it wont pop because of the power that wont be sent to teh vtec from the ecu.
    if that doesn't work just burn it and call insurance
    Under your bed.
    Quote Originally Posted by Arm&hammer
    lirl!
    check and make sure the pins you have going into your ecu are the correct pins, if they are not then it may not be connecting into your ecu which would make it so your VTEC wont engage
    West palm beach
    check the screen in the vtec solenoid, mine was not working yesterday and the screen was clogged, also touch a wire to the battery and the connector and see if it clicks..
    NO ADVERTISING
    -IA MANAGEMENT
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    Just by reading the title, Im going to say check your oil..
    idk if you checked it or not, not reading any posts.. Got to run..
    Rice Rice Vtec
    sometimes u have to clean ur Vtec solenoid!
    95 Civic EX-Traded
    93 Civic CX -Sold
    93 Nissan Altim-Sold
    95 Civic CX- RIGHT NOW!
    What you haven't done, is brought it to us to get it fixed
    lol some of you don't realize technically oil can be called vtec fluid. considering that is whats is sprayed on the cam(s) as vtec is engaged.
    macon
    thanks for all the help i tried everything and nothing worked hell i even changed the oil pump and still it did not work so i just got rid of the car thanks again.
    West palm beach
    Quote Originally Posted by honda4life
    Damn....
    NO ADVERTISING
    -IA MANAGEMENT
    wtf.
    Hamilton, GA
    Damn just read back some lol
    VTEC just :idb: you
    still searching! Hondatwin23's Avatar
    Atlanta\Lithonia
    Lol....owned by lack of vtec
    http://twitter.com/LEGEND_STATUS
    1997 w/1999 civic w/ Built GSR...FS/FT
    long dong silver hondaman050's Avatar
    dallas
    Quote Originally Posted by Hondatwin23
    hahahahahaha
    WOW simple as that vtec no work = sell that bishh LOL
    /Oo ___A___ oO\
    |=_/_______\_=|
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    What about your knock sensor
    92 mx3
    Hamilton, GA
    1. Check the wiring
    2. Check the soleniod it self, screens and all
    3. Check your coolant temp sensors
    4. Check your oil level
    5. Make sure your speedo works
    Newnan
    anytime it happens to me it's low oil.
    learn to english
    D0 W3RK RedEj8's Avatar
    Macon
    Or..
    ROFL..you couldn't get vtec to work so u sold the car..hahahhahha
    It was probably really simple.
