Results 1 to 5 of 5
Thread: auto to manual conversion help
    Shibby hurlyfire7's Avatar
    Default auto to manual conversion help
    ok, so i bought a 1991 DA with a b20b4 swap.. but its automatic, how would i go about converting it to a manual and what would be the best option as far as what kind of transmission i should go with?
    also does anyone know of a good shop to do this work for me at a reasonable cost?
    thanks,
    Murph
    Atldm dude...
    :boobies:
    Southside Ridin HATCH
    What setup are you going with? Boost or NA?
    You need shift linkages and pedal assembly, lines, Clutch, Flywheel, ECU ect....
    Quote Originally Posted by Black4DrEK
    NA
    Atldm dude...
    :boobies:
    Augusta Ga
    i have everything you need except for the transmission ..... came off a 92 DA GSR ... pm me offer ... and u need the clutch hard line(cable in your case) , shift linkage,pedals , upper tranny mount ( hasport) and you will need a new ECU .
    93 sol Si
    95 sol S
    95 sol Si
    Cobb/Cherokee County
