Results 1 to 21 of 21
Thread: obd1 code 9
    EF Squad
    Default obd1 code 9
    Hey i just recenttly got this code and i research about it which is related to the distributor. So i borrow a oem distributor from a friend that has no CEL and tried it on my car n it still throws the same code!?!?
    Additional info:
    -91 crx dx with b20b swap
    EF Squad
    anyone?!
    PRobably wired it wrong during the mpfi conversion! These are the two wires you typically add that go to the distributor.
    warner robins
    SHORT flashes are single digits (1/2 second)
    LONG flashes are 10's (1 second)
    -----CEL # List-----
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor circuit
    65 Secondary oxygen sensor heater wire (black wires)
    67 Cat Converter
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    80 EGR Valve/Line
    86 ECT sensor - Cooling System
    91 Fuel Tank pressure sensor
    92 EVAP Solenoid/Valve/Vacuum Lines
    JJSPEC.COM
    EF Squad
    ^^ thxs i know how to count the cel's blinks
    EF Squad
    the wirings were recheck twice and also use the multi-meter/ continuity tester to check all te wires.
    EF Squad
    what exactly does the cylinder sensor code 9 do anyways? i mean my car drives fine and all.
    probably doesnt idle well... colors are orange and white... i believe...
    EF Squad
    hmm now that u mention my idling is kind of weird. And yes it is orange and white based on this diagram i used.
    Got them backwards ?
    Sometimes the whites get dirty, and are easy to mix with a "faded yellow"
    EF Squad
    my conclusion could be the connector but what is the chances of the connector getting bad?!? and if i keep driving with this code on will it affect my motor in the long run?
    Sometimes they can push out of the back of the connector, and throw a light..
    EF Squad
    so will that code affect the engine or performance?
    IT will affect engine performance because the computer doesn't know where your engine is at time wise in the rotation. I also believe when its throwing a code #9 they batch fire the injectors rather than firing sequentially but i may be wrong about this.
    EF Squad
    hmm no wonder i sometimes hear a little misfiring when im driving at like 70mph. wat about the motor itself will it be affected?
    Well one could assume if the engine isnt getting enough fuel or the timing is off, that yes it could damage the engine.
    it can and will more than likely damage the motor over time or if you drive it hard. drive it like a grandma and you'll be ok until you can fix it at light loads.
    if it doesn't know exactly when to fire b/c of the code it could over time=detonate or severly under time and egt will climb.
    EF Squad
    damn i really need to gget this fix ASAP! how will i start noticing if the piston starts to detonate? i have drive it hard once in a while but not like everyday since i just got the car swapped a few months ago.
    if the detonation is bad enough it'll sound like bb's rattling in a can.
