Results 1 to 16 of 16
Thread: need help with fuses on integra asap!!!!!!!!!!!!!
    the duckster
    Rome
    Default need help with fuses on integra asap!!!!!!!!!!!!!
    i got 2 questions
    the first one has to do with fuses
    if the fuse guide calls for a 15 or whatever is it okay to used a higher number?
    and i was changing fuses and adding some that were missing for some reason
    im not sure which ones i changed but i did this before work today and when i got home my car is dead
    any idea which fuse it might be
    and its a 92 integra btw
    thanks
    Race Ready Developments Member #5
    Rome Crew
    the duckster
    Rome
    anyone???
    lmk
    Rome Crew
    run the size fuse that it calls for. u can burn something up running a higher amp fuse. also if dont know u replaced its hard for us to tell u whats doing what.
    the duckster
    Rome
    okay
    ill go buy more fuses
    i wished i knew what i changed
    ugh
    Rome Crew
    Quote Originally Posted by ducky1177
    ugh
    that would help
    the duckster
    Rome
    i just jumped the car off and let it run for a couple of minutes
    then i went to turn it off and it didnt turn off but the key came out
    wtf
    Rome Crew
    was it dieseling or running like normal
    the duckster
    Rome
    i just let it sit there and idle after i jumped it off
    it did fine
    but when i turned it off it stayed on but the key came out
    it just kept running fine
    i had to put it in first and dump the clutch to get it to die
    Rome Crew
    u need to find that fuse. but if u hadnt said anything about the i would say its something in the ignition switch.
    the duckster
    Rome
    i didnt mess with any fuses that would mess with the ignition?
    just the headlights and stuff
    idk?
    Rome Crew
    the duckster
    Rome
    fixed the problem
    the backup and turn light were keeping my shit on
    lmao
    Rome Crew
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Next time put the correct amp of fuse where it belongs and dont add fuses where there arent any and when you dont have an issue with any electrical components,but glad you got the issue resolved
    the duckster
    Rome
    Quote Originally Posted by STRteg
    reps for you for stating the obvious
    thanks man
    Rome Crew
    Oct 2008
    thanks man
    lol just glad the DA is runnin and cutting off properly with the key lol
    Listen to this guy.
