Results 1 to 20 of 20
Thread: need help clutch prob.
    Rome,Ga
    Default need help clutch prob.
    okay my clutch went out in i replaced it with a new clutch now for some reason it will not pump up i replaced the clutch slave cylinder its in a 93 integra they did a hydrolic conversion on the please help if u no the prob sometimes it will but not much at all in i get no clutch
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    hm what motor is it?
    Rome,Ga
    b18 block with a gsr head.
    Oct 2008
    What tranny? and year of ls block?
    Rome,Ga
    ls tranny in i really dont know the year of the block may-b 94
    Oct 2008
    and they did a hydraulic conversion?
    Rome,Ga
    well i mean it had the conversion but like my car came with cable its a 93 integra rs.
    Sounds to me you need to Bleed it out....NOTE when bleeding it takes many many pumps to get it to pump up!
    Also read what you typed an correct it please I could barely understand anything you said!
    Rome,Ga
    ive bleed it out several times in still nothing it moves barely. in sorry i was in a rush.
    Oct 2008
    Oh ok i get what your saying now alright i thought you were trying to say they altered the tranny i was like wtf,when you replaced the clutch is that the only thing you replaced?
    Oct 2008
    X2 i had a hard time understanding him too
    Rome,Ga
    where the slave master cylinder is that part moves very little i was thinkin it was the clutch master cylinder but it pumpin fluid to the slave cylinder does it suppose to hold pressure??
    Rome,Ga
    i replace clutch pressure plate in throwout bearing.
    bleed bleed bleed adjust pedal also.
    Rome,Ga
    ^^^ i will try6 adjusting the pedal but i think that screw is all the way in where does it suppose to be the pedal goes to the floor.
    lol did u put the throw out bearing back in correct
    Rome,Ga
    yea.
    Oct 2008
    Quote Originally Posted by terrytowe22
    yea.
    mcdonough
    like everyone said bleed it or replace the master cylinder
    Even with a Leaking Master Cylinder it will still Bleed an pump up!
    Bleeding is a Bitch if you dont have the right tools an no partner to help
    Quote Originally Posted by Nateds16
