Results 1 to 3 of 3
Thread: a lil wiring help
    Default a lil wiring help
    so im converting my obd0 to obd1 and i got the wiring out of someone elses car.i have all the stuff to do it but i dont have the instructions.i got the instructions off of rywire but the colors dont match.the jumper harness for the ecu has the three black plugs for the obd1 ecu and the and the two for the obd0.it has two small white plugs one with 8 wires and one with 4. so my question is does anyone kno where this came from or where i could frind some different instructions on the convertion.
    if it's a mpfi car, the adapter harness should be plug and play (assuming you got the correct one) and you'll only have to run a couple wires for o2 and possibly vtec sol and vtec pres.
    if it's a dpfi then you'll have to have the dpfi obd0-1 conversion harness and run wires for the addition of 2 injectors.
    check www.boomslang.us to possibly see another wiring schematic.
    Default thanks
    thanks that really helps look like the same one i have
