Results 1 to 22 of 22
Thread: Home washer/dryer issues?
    Atlanta, Ga
    Default Home washer/dryer issues?
    Alright we have a relatively new Inglis washer and dryer (yr or so) and we had it in our apartment for that whole time. Everything worked perfect. Now we just moved to this new place and all in a sudden our clothes don't dry for shit. I've had to run the dryer like 3 full "towel" setting drys to get clothes completely dry. Even the smaller loads don't dry. Now obviously I can't keep running the dryer 3 fucking times every time I wash clothes.
    I really don't think there's anything wrong with the dryer because it still gets hot as fuck and that's all a dryer really does. I think the washer isn't spinning the clothes dry correctly or something. It does finish its cycles though, but I've noticed it vibrates like crazy, making me think that it may be out of balance or something and not spinning as fast or long as it needs to or something .
    anyone have any ideas on what it could be?
    bottom line:
    worked fine one day
    moved, now clothes don't dry.
    I had that happen when I moved into an older house. First time we used the dryer the same thing happened lol no heat as if you had it on air dry. Even though it worked before at the townhouse. Turned out to be the power source from the house.
    Moved recently to anther house and it works fine lol.
    So check out your power source first
    M.O.B inutero93's Avatar
    valdosta ga
    if you have a multi meter check the socket for the dryer and washer
    dryer 220
    washer 110
    put the multimeter on the right setting i believe its 600 for 220 volts and 200 for 110 volts
    if its good it should read around 225-240 for the dryer and for the washer 120-130 if its only half of that could have a bad wiring in socket
    Got_Purp's Lady Mrs. Purp's Avatar
    Oct 2008
    isn't there a way that the vent from the dryer leading outside gets clogged? I think that's what's wrong with ours... but the men here are just too lazy to fix anything.
    Goon Squads First Lady
    And a half!
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    I think the transmission mount is worn out on your washer
    No but really idk...
    check to make sure the exhaust vent isn't clogged...it'll prevent the clothes from drying even if the element is heating up the dryer compartment.
    grab the washer agitator and shake the whole wash-tub back and forth. sometimes the unit gets stuck and won't spin and a good shake or 3 will loosen it up...have to do it occasionally on my washer. i know when to do it when the clothes seem to be way too wet after the washer stops.
    another thing that can do it is if the washer/dryer is in a non-heated area (utility area in a garage, carport, add-on section of house, etc). if it's too cold in the environment the dryer is in it'll take longer too.
    F.A.N.A.T.I.C. primespark22's Avatar
    lol at this thread
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    :noitacoL
    def. check your exhaust. and you lint screen, hopefully you check that every time anyway, lol... oh and change the oil and plug wires
    Atlanta, Ga
    lololol. thanks for the serious help some of you lol.
    the exhaust is fine and the screen is fine. like i said before, the dryer still gets super hot, i mean i don't notice any difference in heat output from before. it just seems like the clothes are wetter than they should be when the dryer finishes.
    i guess if i can't figure anything out i'm just going to have to rebuild the head. maybe a valve is bent or something lolol.
    general tech is where i ask all my questions. home or auto.
    :noitacoL
    is it still under warranty?
    Oct 2008
    No no no ok ok look all joking aside man seriously now i really honestly believe with all my heart and all my knowledge of washers its most likely a compression problem in one of your cylinders
    Atlanta, Ga
    not real sure... i'll have to ask my step dad. i don't really think anything catastrophic happened to fuck it up during our move though. you thinking service call or something?
    :noitacoL
    if its still covered, then use that shit man
    Atlanta, Ga
    haha. i'll def. have to ask. i gotta go over to my parents' tomorrow anyway.
    Hiawassee, GA
    Mr. Clean having problems with his washer? Ironic.
    -Zach-
    1987 Toyota Pickup - Toy
    I think your Vtec wire isnt plugged in!
    But to be honest sounds like a LOOSE belt
    Augusta Ga
    LOL justin and his Epic threads here lately .... first it was a House build thread ...... Now this .. whats next ??? lol .... imma agree with josh ... i think its low in vtec fluid !!!!!! ROFL +3 man !
    93 sol Si
    95 sol S
    95 sol Si
    turbos
    the filter needs to be washed, take it out and run it underwater if the water pools on top of it then it needs to be washed. This is a common problem with dryers some people never wash the filter they just take the lint off. The real problem is that fabric softner creates a wax build up in the mesh and that makes it hard for the dyer to work properly. This will eventually cause premature failure of the heating element.
    Short story is take the filter and wash it with warm soapy water and dry it off, put it back in
    TOO BIG
    1010011010 Atlblkz06's Avatar
    Hell
    Well you moved the clothes from the washer to the dryer right, you should know if the washer isnt working right.
    My bet is that you have a clogged dryer vent. Move the dryer back and stick one up these puppies in the vent and clean it spotless:
    freezrburn frostbyte's Avatar
    douglasville
    lol its the lint shield WASHER fluid thats low.. aww hell ftw thro a three fity in tha sammitch and drive around the block on it with clothes hangin on a rope flappin in da wind.. nothin like driftin a dryer on a cold day least ya ass stays warm..
    U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!! [SIGPIC]
    turbos
    Quote Originally Posted by frostbyte
    TOO BIG
    Oct 2008
