Results 1 to 40 of 41
Thread: D16Y8 Intake Manifold on D15b7 will it work???
    Southside Ridin HATCH
    Default D16Y8 Intake Manifold on D15b7 will it work???
    just as title says will it fit???
    anyone??
    Yes
    thanks man , any more replies?
    Woodstock, Ga
    yeah it will fit man..
    No it will not fit!
    ^^^ WHy not ??
    You will see when you look at the two, an compare the head an the intake, when you bolt it up it will have a vacumm leak,an leak anitfreeze into the motor
    Scottish Scotsman's Avatar
    on the road to recovery
    you can however use a z6 mani
    you can just get the right gasket!
    BTW you can use the Y8 if you use the right gasket too
    ^^^ damn you guys are confusing me!! soo it For sure will NOT work or Can i use a gasket???
    both will work with the right gasket
    lol it will work with either or, just make sure you get the right gasket! lol
    Sorry i am just in the mood to pick on ya!
    o haha , gotcha so get a Y8 intake gasket and it will bolt up and work fine? THanks..
    the Y8 manifold is from an auto.. does that make a difference.?? its goin on a Five speed!!??
    the motor has nothing to do it being an auto to 5 speed
    Quote Originally Posted by Black4DrEK
    ^^^i knoe im talking about sensor's and stuff..
    same!
    ^^ Ok well i just took the old mani off. The Y8 doesnt fit.. there are metal block type things that are blocking the mani from bolting on correctly
    i still haz the z6 mani
    thats what I said
    ^^ You said buy the Y8 gasket and it will work...,.
    go to post #5 I said the D16y8 will not fit
    after trying to do the Y8 thing , I just put ALL stock components back on and now the car isnt idleing correct!!! It just goes High low high low high low.!!! WTF I pluged everything up correctly!!!???
    What could be this problem.. The original intake gasket was messed up soo i need to replace it, < could that be the Damn PROBLEM!!?????
    The Y8 manifold fit fine with playing around on mine...and MANY others.
    That sounds like a vaccum problem when it idles like that.
    yes it has a Vaccum leak!
    thanks you guys^^^
    the reason mine didnt work is the mani and throttle body from y8 was an auto so plugs and ect. wouldnt hook up correctly...
    thanks again for the help
    Woodstock, Ga
    x2
    Seafoam it too...
    Ok i just replaced the intake gasket (brand new) works fine. NOW It is still doing the reving up and down! and there is LOTS of WHITE SMOKE coming from exhaust??? WTF??? everything is pluged up correct
    O and one thing.. The "Evap Purge Solenoid Valve" broke on one of the lines!! Is that the problem?? and is this part important??
    That is the ONLY thing I can think of????? HELP!!
    bump!
    sounds to me that coolant is leaking into the intake system somewhere
    ^Same here...you did something wrong.
    You put it all back on EXACTLY the same? ALL new gaskets?
    I think he bypass the Fast idle valve an ran the hose to the intake
    Everything is correct im 99% sure.. but the throttle body gasket is F'd also. Could the throttle body gasket make all that shit happen??
    i know this is probly a simple thing but im in the Garage pissed off cuz i keep looking over every hose and shit and i see nothing wrong!! LOL
    White smoke and crazy idle, SOUNDS like something bigger is the problem! but i dont see how.
    No check engine lights!
    bump up the jam!
    bump , need help asap. still f'd up! If the anti freeze went into intake somehow is the motor gone???
    All brand new gaskets and still white smoke and crazy idle..!!
    Augusta Ga
    check your PCV valve ... thats prolly your whole problem .... make sure it doesnt have a leak and its not jus left unplugged ...
    93 sol Si
    95 sol S
    95 sol Si
    this will not cause white smoke like he is saying
    Take a pic up close so I can see what you did
    some how anitfreeze is getting into the motor, does not mean the motor is bad, means you got eith a bady gasket, or a coolant line hook to the intake causeing it to smoke... Which manifold you got back on the Stock D15b?
    ^^ thanks Tech5 i got it done now. the problem is solved. the new throttle body gasket fixed the white smoke.. and the idle problem was the old gasket 'residue' was still on the head and port for mani.. so it was causing leak!! lol. simple problem fixed finally. O and i had to bleed the coolant valve thingy
    thanks to all that tried to help. reps if i can
