Results 1 to 6 of 6
Thread: h22a4 need help
    boostedf22b
    Riverdale
    Default h22a4 need help
    i have a 90 accord motor is in the car everything is in place spark is good right firing order and getting gas but the motor will not turn over it jst cranks and cranks and cranks could it be my ecu since i have p28 chipped out but it was for my last setup i had a jdm f22b boosted could this be my problem i thought it would at least start it just wouldnt read vtec need suggestions like asap.
    Unknown
    Oct 2008
    compression check/leakdown check????? fuel + Heat + oxygen = fire: fuel = gas, oxygen = air, heat = compression+spark. if you have gas, air, and spark but no compression then you have no fire!!!!!
    boostedf22b
    Riverdale
    ok but i have spark and im getting gas the motor is building compression its like something is keping it from turning over right now im about to check my injector to make sure their putting out gas
    what injectors are you running and what injectors were you running when the ecu was on the boosted f22?
    boostedf22b
    Riverdale
    i am running the 450 inj those are the same ones i was running with the f22
    You can bring it to us, and we can fix it 678-567-9384
