Results 1 to 7 of 7
Thread: i lost 9mpg
    rockem sohcem robot
    Default i lost 9mpg
    the other day i bought a three step engine cleaner. one to spray in the throttle body. one to suck in the vacuum line.. and one for the gas tank. i started it up. ran fine. went to work. when i left work my car was idling at like 1100.. took the iacv off and cleaned it.. nothing.. cleaned and lubed the tb... nothing.. then last night i smell a rotten egg smell.. so im thinking its the cat stopped up.. i was getting 28mpg before.. now im around 19.. horribbblllee.. any suggestions? i might just take the cat off and knock all the stuff out.. know anyone with a test pipe or someone that will weld on a straight pipe? my cars an obd1 swap and the o2 sensors are cut off so i dont think ill have a problem. suggestions.. intelligent ones.. will be repped.thanks
    "TheCrew"
    Crew member #3!
    just because I came in late I am leaving one two open haha
    turbos
    if u dont have to have emissions just go on ebay and get u a test pipe.
    What was the name of the product u bought?
    TOO BIG
    F.A.N.A.T.I.C. primespark22's Avatar
    random bump for your car,i like
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    Hates streched tires DunDunSkeert's Avatar
    Misawa, Aomori, Japan
    The egg smell is definitely your cat. No you can't just knock the stuff out, your cat is a goner . I don't think your cat is the only thing causing the mileage drop. What product did you use?
    Newbie Photodude RBS's Avatar
    All Over U S A
    you prolly gotta just run it through the engine a little bit longer
    rockem sohcem robot
    b12 chemtool
    "TheCrew"
    Crew member #3!
    North Augusta, SC
    I'll trade for your 19 mpg. lol. Anyways, good luck with it man.
    Back to being stock and slow
