Results 1 to 27 of 27
Thread: D15b swap vtec probs...
    Default D15b swap vtec probs...
    Ok so i got a 94 civic ex coupe... its got a d15b swap with a p28 ecu i cannot figure out why vtec isnt working.. any ideas would be great!!! ive ran a wire straight from the vtec solenoid to the ecu pin and it still doesnt work??
    Augusta Ga
    any cel's ? wut pin did u wire the solenoid an pressure switch 2 ? you cant hear vtec in a sohc so if it aint throwing codes ... u have vtec .
    93 sol Si
    95 sol S
    95 sol Si
    its throwing EGR code and O2 Sensor Code... and yes u can hear vtec in the d15b lol
    Augusta Ga
    not as loud as my GSR .... well ... EDIT: as loud as my gsr WAS .... lol
    the d15b i had it was a very smooth non noticeable transition .maybe yours is diff i dunno .
    93 sol Si
    95 sol S
    95 sol Si
    the d15b vtec typically has the strongest vtec transition of any sohc vtec engine lol.
    Quote Originally Posted by Redrum478
    ehh maybe you need to recheck your codes, i dont believe any car with a p28 has a EGR
    Augusta Ga
    it doesn't .
    93 sol Si
    95 sol S
    95 sol Si
    thats right it came with a z6.. and was swapped with a d15b now its thinking theres a EGR but there really aint any way to get rid of the code?
    You need to recount the flashes, the p28 will not set a EGR code
    Augusta Ga
    none of my z6's have EVER thrown a egr code b4 .
    93 sol Si
    95 sol S
    95 sol Si
    no kidding
    well i pulled all the codes had a vtec oil pressure switch code fixed that... and a 02 sensor code fixed that vtec still aint working..
    The oil pressure switch will def make vtec not engage. have you cleared the codes and drove it again?
    yep still no vtec....
    Augusta Ga
    get a diff ecu .or try reseting the ECU and see wut codes . also pull the WHOLE vtec solenoid off and clean it ! ..
    93 sol Si
    95 sol S
    95 sol Si
    roberta
    not bashing the guy you got it from...but joe told me that he was pretty sure that was a automatic ecu...i got a manual on if you want to come down to macon and try and see if you get vtec
    roberta
    and if you need the ecu ill trade for that si lip thats on it
    im gonna keep my lip... ill buy the ecu from yuh tho... what kinda ecu is it?
    even if its a auto ecu.. its a p28 it will still hit vtec my friends running a auto ecu and its fine.. something else is messed up somewhere...
    middle ga
    what pin did you wire the vtec up to on the ecu? make sure the solenoid is on a4 and pressure switch on d6
    its all correct on the wireing... ive tested the vtec soliend and it says to jump the wire comeing from it to + on the battery and if you hear a clicking its working.. did that works fine i even replaced vtec oil pressure sesnor... still dont work its got me puzzled...
    middle ga
    if the wires are not right at the ecu then vtec will not work regardless of weather the solenoid and switch are good.
    Its a 94 civic ex.. already came with vtec i double checked it to make sure it was all correct the wireing it right i even ran a wire from the solenoid to the ecu pin.. should i try runin wires from the pressure switch to the ecu to?? its got a jdm d15b motor with a p28 ecu
    middle ga
    please tell me you checked the oil....i know it sounds retarded but i have actually given that advice and solved a vtec not working problem
    yep checked the oil its full... first thing me and cole checked haha
    B-Town Crunk Force
    Statesboro, GA
    I know this one dude who swapped a b16a into his ek but he couldnt figure out how to wire up his vtec, so he just ran the vtec wire to his horn.lol vtec on demand right there son. sorry i know thats not helpful to your dilemma but i felt compelled to share it.
    lol thats gotta hit mad V-TAKKK!!!
