Thread: ac problem! No!
    Nov 2003
    Default ac problem! No!
    ok I have a 98. Integra and the ac was blowing ice cold last night and it was so cold that you can see the it comming out of the vents. This morning I got up andthe damn thing would not go on at all . It would not even kick on the compressor.
    Does anyone know the problem?
    Thanks
    Wheres the money?
    McDonough
    check the relay if not the relay check and see what the system is charged to( if theres not enough freon in the system the compressor wont come on)
    roberta
    Quote Originally Posted by tank500999
    would also agree,if there isnt enough freon or is to low there is a sensor that wont turn on the compressor so you cant burn it up.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    if you could see it streaming out of the vents id say you lost the evaporator core as freon was leaking up through the vents. its in the box with the heatercore. theres a vent that goes from the heater core to evaporator core when moving from hot to cold.then the fan blows through it. also as stated not enough freon due to the leak means no compressor will com on. good luck, we dont have too much longer then it will be air conditioned out side.
    Nov 2003
    thanks for the help everyone. I will try the relay but where is it? I am not to smart when it comes to ac
    Check under the fuse box. Do you have a Digital Multi Meter?
