from what ive gathered, not sure if this is correct.
17 - VSS (not worried about this one, my tach and speedo work fine)
41 - heated oxygen sensor heater?
48 - heated oxygen sensor
after reading one guy replaced his vx o2 sensor and his gas mileage went from 35mpg ( where im at ) back up to 45+ im thinking it will be worth it to do it. just want to make sure of a few things. the heated oxygen sensor im assuming is the 5 wire o2 sensor on the top of the header. as for the heated oxygen sensor heater, i have no clue what that is? i also reason another place that code 41 is something else like the lean air fuel sensor. if anyone knows of good reliable page to get correct cel codes let me know! and if there is any further testing i need to do to check and see if it does need to be replaced or if there is other things that need to be checked that could cause it to go off.
