Results 1 to 25 of 25
Thread: what does NOx ppm mean?
    Marietta, GA, USA
    Default what does NOx ppm mean?
    took my car to get emissions it fail on the NOx ppm it read 1152 and whats allowed is 773. my car is a 92 sc300. i asked the guy what it means and he said its not burn enough fuel and someone else said that it didnt have a comp so he would have to go through the whole car to find the prob. and a third person told me tha it means it has to much carbon build up.....any ideas?
    Brandon
    Foxbodies?? Anyone?? ranger250x's Avatar
    LIL-burn
    NOx is simply put burned HC's. it is read in parts per million(ppm). too much NOx can be related to a failed egr valve. has you check engine light come one
    1999 Mazda Miata- For Sale $4,500 FRIM!
    Marietta, GA, USA
    no. the onlt light that comes on is the o/d light cause it used to be an auto and my abs light but thats cause it has dirt in one of the sensors. thats it tho.
    Brandon
    If its a OBD1 car meaning 92-95 then no check engine light dont come on.. NOX is to much heat in the exhaust could be a egr valve but most likely it will be a bad CAT...But if the cat burned up then something might have caused it to go bad, faulty tuneup , bad O2 sensor , ETC
    Marietta, GA, USA
    yea its OBD1. is there a way to find out what the problem is exactly with out have to just start buying parts...lexus is way proud of their stuff so i cant afford to much...lol
    Brandon
    Marietta, GA, USA
    this is what my emisions reads.....(25/25 test)HC ppm= reading 7 allowed 111, CO% 0 allowed .61, CO+CO2% 14.5, NOx ppm 1152 allowed 773.
    (50/15) test HC ppm 12 allowed 114, CO% .17 allowed .63, CO+CO2% 14.4, NOx ppm 686 allowed 853
    Brandon
    Woodstock
    Start with the EGR, most can be cleaned without replacing it. Then check o2 sensors. You should know if the cat has gone bad, because all of your other numbers on the emissions test would have been high too.
    Wrong NOX an HC yes but not all of them! But on honda/acura the nox being high can also be just the cat..Not all cars has EGR valves either...)2 sensor will not make NOX be high only CO HC..And you cant clean a EGR valve an it be fixed you can clean the ports but if a egr is causing its b/c its bad...
    Quote Originally Posted by CrbnIntegra
    Woodstock
    I'd try cleaning or replacing the EGR. My car has an EGR vaccum hose which was leaking causing me to fail, it was an easy fix.
    Marietta, GA, USA
    yea ill try that....im gonna seafoam it too maybe that will help
    Brandon
    I have seen SEAFOAM makes the test worse than helps!B/c it makes the exhaust temps higher, there for your NOX gets higher!
    Quote Originally Posted by BrandonR18
    Depending on how high the NOX was you can take it to a emission tester an let it cool down for about hour or so then retest it , an it might pass! I have done this mannny times out my shop!
    Marietta, GA, USA
    it passed on the 50/15 test with no problem but it failed on the 25/25 test.the NOx was 1152 and only 773 is allowed...if i seafoam it i would chang the plugs in it as soon as i am do and that takes about an hour or so....
    Brandon
    Certified Gearhead Pavlo's Avatar
    Alpharetta
    Change your oil.
    Representing VWs.
    Marietta, GA, USA
    changed.... with mobil 1
    Brandon
    i pmed you.... and one more thing.... go get a "guaranteed to pass emissions" thing you put in your oil.... it at auto zone/ advance. and use that too
    or you might need new O2 sensor!!!!!
    GOOD LUCK!
    Winder,Ga
    If all else fails adjust your timing....it helped my girls car by like 2000ppm bc her readings were 4300reading and 1200ppm allowed....with 2 degree difference on the timing she is close to passing.....
    retard yes Not advancing!
    Quote Originally Posted by masanomi3
    ACTUALLY!!!! retarding didn't do **** for my car. ADVANCING it did. retarding it doesn't always do it, it just depends on the car.
    ACTUALLY!!! I wasnt talking about your car! With his NOX high it needs to be retarded!!! TARD!
    Quote Originally Posted by nllnellie
    step sticky stephen's Avatar
    just got buy some de-natured alcohol and pour it in your tank. they sell it at home depot. there's 2 sizes, a gallon can and a smaller one. get the smaller one & pour the whole thing in your tank. don't buy that "guaranteed pass" stuff.
    All the shltt yall telling him isnt going to help!!!! everything yall are telling him is going to raise the NOX levels way beyond what it is now!!!! Listen to what I have been telling you!!!! O2 sensor will not affect the NOX levels!!!! Only HC CO...Oil change will not even come close to dropping a .1 point in anything!! yall all are NOOBS when its coming to this so stop telling him stupid an wrong shltt!!!
    Alpharetta
    Oil change will make a huge impact on older cars, run an older cars that has some blow by with dirty oil and run it with clean, if you don't see a difference then you are a tard. My Corrado will not pass with the current ECM program unless I change the oil, I am guessing you are a technician too, so next time you have a car that won't pass emissions do just that and compare the numbers.
    Representing VWs.
    Marietta, GA, USA
    thanks people....
    Brandon
    Winder,Ga
    Ok....you can stop being a f**king d**k!!!!! I was just helping out the man.....I didn't say to retard or advance bc I don't know about his car and it's different from mine....I'm f**king emission certified and they give u a piece of paper saying that if you fail NOx, the things that can affect it are but are not limited to ....O2 sensor...timing...cat.... and egr....soooo if you wanna be a d**k go ahead....just don't talk s**t!!!! Were all just here to try and help each other out!!!!!1
