Results 1 to 17 of 17
Thread: motor explained??
    WillAgreeForReps!!
    The Town of Lula
    Default motor explained??
    ok so i have helped my buddies and worked on a few cars... but i'd kinda like to find a pretty good, in depth explination of how a motor works exactly. i kno that alot of u out there r thinkin what a retard but i'm new in the game so whatever. so plz keep the hating to yourself. thanx for any info
    Stang Mod slostang's Avatar
    Southside
    suck squish bang blow...
    Athens/ATL
    Air enters through intake valve
    Fuel injector squirts in fuel
    Spark plug goes kaboom
    pushes piston down
    Motion of other pistons being pushed down turns crank
    makes power.
    That's in the most BASIC sense.
    Don Mon SiRed94's Avatar
    Morrow 30260
    Well, there is an external casing that has two magnets mounted on either side of it. Then there is an armature/rotor assembly that is wound with copper wire that protrudes through the center of it and out through the front of the casing. Then there is usually a gear connected to the portion protruding from the casing. And on the other end of the armature shaft there is a cap to the casing that contains some brushes that transfer electrical current to the armature. When the casing is charged with - current and the armature is charged with + current the armature will begin to spin inside the magnets.
    Southside
    repped for explainng a MOTOR!!!!
    Athens/ATL
    pretty sure he's talking about a car engine/"motor"... not an electric motor.
    Morrow 30260
    Quote Originally Posted by slovic-fcc
    somebody got it....
    WillAgreeForReps!!
    The Town of Lula
    somebody got it....
    so the "ALL MOTOR" section on this forum is electric cars then?
    WillAgreeForReps!!
    The Town of Lula
    u kno what i mean. take the hating elsewhere
    IA Member jtaylor48's Avatar
    http://en.wikipedia.org/wiki/Internal_combustion
    If you don't know by now, wikipedia is the ****e
    Gas is too expensive to drive hard and my insurance can't take anymore fast.
    WillAgreeForReps!!
    The Town of Lula
    QUOTE=jtaylor48]http://en.wikipedia.org/wiki/Internal_combustion
    If you don't know by now, wikipedia is the ****e[/QUOTE]
    rep for info and absense of sarcasm!!!
    Intake, compression, ignition, exhaust.
    I'm glad someone knows the difference!
    Athens/ATL
    Quote Originally Posted by BikerBrody
    Quote Originally Posted by bikerbrody
    where are my reps for finding you a diagram AND explaining it?
    Quote Originally Posted by 81911SC
    Actually its
    Intake, Compression, Combustion/power, Exhaust
    Intake
    First stroke, starts with piston at TDC (Top Dead Center). This term refers to the location of both the piston and the crankshaft. TDC refers to the point where the piston is at the top of the bore and the crankshaft is at 0 degrees of rotation. Due to the geometry involved in connecting the pistons linear travel to the crankshafts circular motion, it is possible to have the piston at the top of the bore and the crankshaft located some degrees before or after 0 degrees of rotation.
    Compression
    when the crankshaft has reached 180 degrees after TDC, it is referred to as BDC or Bottom Dead Center. At this point the piston is at the bottom of the bore and is ready to begin its travel back up the bore to compress the air and fuel taken in on the intake stroke.
    POWER
    When the piston returns to the top of the bore again, the crankshaft is now at 360 degrees of rotation. At this point the mixture ithat is compressed is expanding rapidly because of the combustion event caused by the ignition system firing the spark plug. This expansion is where the negine produces its power and actually forces the piston back down the bore and applies rotational force to the crankshaft.
    EXHAUST
    The Final stroke begins when the piston returns to BDC and begins to push the expanded and burned up gases back up and out of the cylinder to clear it for the next incoming cycle. At this point the crankshaft is at 540 degrees of rotation and will complete the cycle at the top of the cylinder at 720 degrees of rotation.
    Real PRESSURE-VOLUME (p-V) Cycle (look it up)
    Also look up:
    Engine Revs vs Engine CYCLEs
    Volumetric Efficiency
    Standard Conditions
    Absolute Conditions
    Air Density
    Air Flow
    Mass Flow
    KPA/BAR vs INHG/PSI
    Brake SPecific Fuel Consumption
    Brake Specific Air Consumption
    Lambda
    Learn all that an you will know more than 99% on this site an other sites, and more than most "engineers"
