Results 1 to 12 of 12
Thread: computer code
    Default computer code
    could anyone please tell me what computer code this is 37820-p05-a01
    Default pic
    and here is an picture of it the guy said it had an chrome chip. could this cause an b18 ls engine to run like crap?
    Attached Thumbnails Attached Thumbnails -ecu-jpg
    Augusta Ga
    po5 is a cx ecu i believe and if you running a Ls on it the fuel maps are WAYYYYY different !! i recomend a p06 ecu or a p75 for a LS ...
    93 sol Si
    95 sol S
    95 sol Si
    Default hy
    well he said he had the fuel upped or something an a b20 map put on it with an chrome chip so should i get a different computer?
    Augusta Ga
    i would get a stock p06 or stock p75 and see if they run the ls better ... that should make the car run better ..... ? and when u said it runs like crap ... wut do you mean ? spit n sputtering ? wuts the symptoms ?
    93 sol Si
    95 sol S
    95 sol Si
    Default hey
    yeah its sputtering when you hit the gas then it goes
    Augusta Ga
    yea try a stock p06 or p75 ... my old chipped p28 done this .... you can also use a OBD1 PR4 ecu ... most pr4's you see are obd-0 but there are a few that are obd1 which the pr4 and p75 are pretty much the same ecu ... the p06 is for a d15b7 . and so forth .
    93 sol Si
    95 sol S
    95 sol Si
    Default ok
    thanks for the help an if the p06 is for an single cam engine wouldnt it do the same thing
    Augusta Ga
    nah not as bad ... i ran my ls on a virgin p28 all day with no problems ... but it had a vtec solenoid CEL ... which i could careless about it then .. but i do care bout it now ... so i got the stock p75 and i really cant tell a diff between the p28 and the p75 ( driving wise ) :boobies:
    93 sol Si
    95 sol S
    95 sol Si
    Default hey
    i ll see if that helps thanks
    Augusta Ga
    np .
    93 sol Si
    95 sol S
    95 sol Si
    Augusta Ga
    oh yea i forgot .... if it has a reburnable chip inside then u can take that one out and have mainstream or battleground reburn a map jus for that engine ... and see if that works .
    93 sol Si
    95 sol S
    95 sol Si
