Results 1 to 13 of 13
Thread: b16a2 cam cap help
    slick fricks sikfricks's Avatar
    ROME,GA
    Default b16a2 cam cap help
    i have a 99 si b16a2 i am in the process in building it up na when i took the cam caps off i found some grooves in them so is the only option to replace them with oem ones
    Attached Thumbnails Attached Thumbnails -0_imag0104-jpg
    <img src=http://www.importatlanta.com/forums/image.php?type=sigpic&userid=19661&dateline=1274467236 border=0 alt= />
    like normal ware grooves or is it pitted type grooves.
    looks like normal ones...when you install the new cams, lube them up with either oil or assembly lube...<< I use assembly lube...an you have to install the cam caps in a certain order an tighten them in a seqence you know that right?
    ROME,GA
    i know about the sequence and that the have to go on the one they come off of, there actual grooves i thought the were supposed to be smooth
    Quote Originally Posted by sikfricks
    like if u run your finger nail across them u can feel it. got any better, clearer or bigger pix
    like no mo says if you can feel them with your finger nail then yea thats not good..if your installing new cams you can just take a 2000 grit sand paper an smooth it out, an you will be ok
    Unless your head is scared up too...mine was on that same motor and i had to buy a new head... a machine shop can fix it but they told me if i was looking to do performance stuff i should buy a new head but my head was completely scared up...
    Quote Originally Posted by eghonda88
    correct
    true but going by his pics it doesnt look bad at all,, you will be fine
    Yeah he might be fine now...but maybe later it might get F**ED up so just check em every oil change...
    lol that would be fun...Good luck with that
    ROME,GA
    yea i can feel em not all of them are that way the bottom feels fine just two of them the block was scared on number 2
    your moms house
    if it bothers you you can have it line bored or honed
